Colder = Leaner?
Discussion in 'F/I Mods & Tuning' started by NHXRUNNER, Nov 17, 2017.
  1. NHXRUNNER
    7,749
    219
    Is AFR calibrated to a certain ambient temperature? I don't remember going lean last winter. But since the weather has shifted into the low 30s and 20s all of a sudden I'm seeing 12s in boost and I find myself staying out of boost now. Is it normal? I'm running the 2.825 pulley and no FPR mod....
    Could it be related to a plugged up fuel filter? I did the fuel pump upgrade just prior to installing the blower (1.5 yrs ago) and haven't ever changed it.
    Thoughts?
  2. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    848
    29
    Changing the filter would be a good place to start. I see a lot of complaints this time of year, many times it’s summer blend gas in cold weather. Do you have fresh fuel in the tank?
    I had trouble with the fuel hose in the tank cracking. The Leak slowly got worse, and truck got hard to start, lost power,and run lean.
    If you notice the engine spins over longer before starting, that would point at a cracked line.
  3. NHXRUNNER
    7,749
    219
    Fresh fuel, no hard start issues, no lost power....I threw in the FPR mod and my AFRs fattened right up. Hopefully I can pull that off once I get the filter replaced.
    What should I be looking for in fuel trims? And what will that tell me?
  4. wolfpack_5150
    wolfpack_5150 Jangley
    Jan 13, 2012
    303
    17
    Lmao, yeah i notice a large lack in mileage whenever i try the boost reference (sometimes i try different things in diff weather or if im hitting large elevation changes). I mean u never know unless u try, plus we all like to tinker right?
    With boost referencing i went from 11 or 12s to a rock steady 10 or maybe lower (gauge only sees 10:1) with the boost reference. Def lost some get up and go.... felt like the truck was drowning in fuel
    That said, in about 30k miles i dumped some nasty fuel out of my fuel filter (the one from urd). It was dark, with alot of sediment on the bottom of the glass i poured it in.
  5. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Good new. Its just simple fluid dynamics. When the air gets colder since our superchargers dont have a boost limiting bypass, we increase boost as the temp gets colder. You are technically running leaner because you are forcing more air in. Im in maine and i run the fpr mod all winter otherwise i lean out like you. Once its warm out again no problems. One day i gave it the beans and it was -20 out and i had about 1.5 psi more boost than at 40 the day before.
    There may be other small factors but thats the main thing going on.
    XMPLRY808 likes this.
  6. o0opackersfano0o
    Jun 23, 2016
    416
    91
    What the hell? Where have u been hiding. Where in Maine are you at?
  7. blackx-runner
    blackx-runner "White Flash"
    7,581
    13
    denser air = more air maybe
    XMPLRY808 and woodex m.e. like this.
  8. NHXRUNNER
    7,749
    219
    Just would have thought the ECU would adjust for it......
  9. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    I lurk about once in a while. Not super often any more, things seem to be slow here lately. Also im a TRD OR and not an X runner so i spend more time just reading. I am in Brunswick, but im originally from Caribou and frequent there during the winter.
    wolfpack_5150 likes this.
  10. woodex m.e.
    woodex m.e. Member
    Jan 25, 2014
    65
    Thats the thing, i dont think it can. I think its maxing out the injectors and their signal and thats why the oem fpr mod seems to do the trick. If the weather is cold enough its almost the same as running a smaller pully.
  11. XMPLRY808
    XMPLRY808 Active Member
    Dec 5, 2014
    401
    74
    Should get the urd maf cal with map sensor;)
