quicky06
- May 20, 2007
- 754
you cant just change the reluctor ring in the trans they should all be the same. you cant use a pcm flash for the pre runner either due to the tire dia. being diffrent. if i remember correctly if you do the math the gear ratio nd the tired diameter cause the x and the prerunner to rotate at the same speed.
