Creaking clutch (how to fix)
Discussion in 'Stock Performance/Mechanical' started by AsianTaco, Aug 29, 2007.
  1. AsianTaco
    AsianTaco Active Member
    Jun 12, 2007
    1,113
    How do i fix it? lol. I put grease on the piston area, but it came back. I went to the dealership, and they are like well we are going to need all day to look at it so you will have to leave it here in the morning. I can't do that I work, and I worry if I do leave it there, they might take it out for a joyride or something all day, and the problem probably only takes like 5 minutes to fix. So any ideas?
  2. akakrill
    akakrill Member
    Mar 26, 2007
    944
    same problem....and no dealership idiot is touching my Super X...
  3. XxRuNnAxX
    XxRuNnAxX New Member
    Jun 28, 2007
    383
    They said they can't fix it... well mine did. The TSB's were for the 05-06... they CLAIM the new parts are in the 07's... which was not what I was tellign them. I told them to fix it and they said the squeaking was normal... I almost choked a ho:bird: ... All I know is its this bushing thing... I believe lol wait for spyder to tune in:top:
  4. lucke
    lucke New Member
    i just got mine taken care of the past weekend. its a ~2 hour job to replace the pedal, bushing and something else.
    thats why we have a TSB and warranty for.
  5. FuCt
    FuCt New Member
    Jun 1, 2007
    318
    yeah i just had my RR 06 done weeked b4 last. i dropped it off on a sat. morn at 11 am, they were supposed to do the TSB on it, said they had all the parts. they took it apart and said they couldnt get it back together till parts came in. Got it back Tuesday eve. doesnt squeek anymore =D MAKE them do the TSB tell them it must be fixed or ur gunna park it on the service counter.
  6. BSPX
    BSPX New Member
    May 14, 2007
    581
    i took the TSB to the dealer multiple times. They said it was normal, I said no its not, I've driven standards blah blah blah.....long story short. I said OK, i have a squeaky clutch I want fixed under warranty, there apparently isn't a TSB out for it....but I have a couple papers here I think might help and I'll leave them on the seat, HOLLA!
  7. FuCt
    FuCt New Member
    Jun 1, 2007
    318
    well there IS NOT a tsb for the 07s. But if u make alot of noise they gotta fix it. Tell them if they fix that for other people why not for you? And u can always try the next toyota StEaLerShIp
  8. tacoturbo
    tacoturbo New Member
    May 24, 2007
    97
    Aloha guys. I think this might help. I've had the creaky clutch before. I work for Toyota and the first repair under the TSB lasted for about 6 months. The creak came back worse than ever. I think I found the problem and solution. The clutch pedal arm is a composite (plastic) material and the pivot point on the plunger shaft mates in the back. What I've noticed is that over time the shaft has a tendency to rotate alittle, enough so that the pivot point binds and causes a creak that is heard and felt in the pedal as it's depressed. Mine creaked and vibrated on the first initial travel of 1 1/2 to 2 inches. All I did was to rotate (center) the shaft untill it felt like it was in the pocket again. Squeak, creak and vibration is gone. The cure was instant and has not returned for 2 months now. As an experiment I rotated the shaft as if it was out of line and the creak returned. To me the problem is identified and solved on my X. Try this it may work and save you a trip to the dealer. BTW, I didn't lube the pivot at all. I hope this helps. The creaky cluch drove me nuts!
    Steve
  9. rpmspeedyblue
    rpmspeedyblue New Member
    1,363
    ^^^ Good info. I'll see if it works for me.
    Picture of the unit that squeaks
    #9 rpmspeedyblue, Aug 29, 2007
  10. AsianTaco
    Jun 12, 2007
    1,113
    Thanks, I'll give it a shot. But I tried greasing that shaft part. I guess it doesn't work. How do you rotate the shaft though, by hand? tool? And last but not least what is TSB?
  11. rpmspeedyblue
    1,363
    TSB-Tall Sexy Blonde :smile: For real TSB =Technical Service Bulletins-A technical service bulletin (TSB) is issued by the manufacturer. More commonly known as a "secret warranty," a TSB is distributed to all of the manufacturer's dealerships and it often instructs service personnel to fix problems covered by the TSB free of charge, but only if the repair is necessary to resolve a customer complaint. TSBs are also issued regarding updated part installation and repair instructions, among other items.
  12. Spyder327
    Spyder327 New Member
    7,098
    TSB stands for Technical Service Bulletin, it's basically a sheet of paper that says certain vehicles may experience a certain common problem and tell what parts need to be replaced.
    It also tells what VIN numbers the repair should apply to.
  13. AsianTaco
    Jun 12, 2007
    1,113
    So i'm guessing this "hush hush repair on sheet of paper" isn't available for 07s? lol.
  14. Spyder327
    7,098
    It's not a "hush hush" thing. It's meant to help technicians diagnose and repair common problems. No it doesn't apply to 07's, but that does not mean that tey can't fix it, it just means they can't submit the TSB to toyota warranty as their reason for repair.
  15. tacoturbo
    May 24, 2007
    97
    I used a pair of pliers to grip the shaft and rotated it a bit untill it felt centered. Creak all gone!. It worked for me.
    Steve
  16. vinnieb0i
    vinnieb0i New Member
    Feb 12, 2007
    334
    Hmmm im so lost following this. Mayb i need to crawl under there and see what shaft your guys are talking about. If some1 could a pic would be helpful.
  17. Celiblue
    Celiblue New Member
    May 19, 2007
    451
    damn thanks, i will be giving this a shot cause work and school own ALL my time
  18. tacoturbo
    May 24, 2007
    97
    Its the metal shaft that is pushed by the clutch pedal into the firewall. Take a pair of pliers and rotate the shaft alittle. The shaft will want to center itself at the pivot point between the clutch pedal arm and the head of the shaft. You can lube it if you want to, try graphite based lube. If not probabaly anything will work.:biggrin:
    Steve
  19. tacoturbo
    May 24, 2007
    97
    BTW, I tried turning up my stereo really, really loud and wore really, really thick sneakers.....didn't work. I could still feel and hear the creak.:laugh:
  20. FuCt
    FuCt New Member
    Jun 1, 2007
    318
    the loud sterio works for the "sewing machine" engine tick that my truck has had since new. Got the tsb done for that too, new exhaust mani. No change.
