SignUp Now!i just got mine taken care of the past weekend. its a ~2 hour job to replace the pedal, bushing and something else.
thats why we have a TSB and warranty for.
Aloha guys. I think this might help. I've had the creaky clutch before. I work for Toyota and the first repair under the TSB lasted for about 6 months. The creak came back worse than ever. I think I found the problem and solution. The clutch pedal arm is a composite (plastic) material and the pivot point on the plunger shaft mates in the back. What I've noticed is that over time the shaft has a tendency to rotate alittle, enough so that the pivot point binds and causes a creak that is heard and felt in the pedal as it's depressed. Mine creaked and vibrated on the first initial travel of 1 1/2 to 2 inches. All I did was to rotate (center) the shaft untill it felt like it was in the pocket again. Squeak, creak and vibration is gone. The cure was instant and has not returned for 2 months now. As an experiment I rotated the shaft as if it was out of line and the creak returned. To me the problem is identified and solved on my X. Try this it may work and save you a trip to the dealer. BTW, I didn't lube the pivot at all. I hope this helps. The creaky cluch drove me nuts!
Steve
