SignUp Now!The only fear of running to much oil would be the chance of the crank counter weight hitting the oil and aerating it....But if you add exactly 5, there shouldn't be any issue. Expeciialy considering there oil pan sub assembly puts a good amount of clearance between em...
I would love to see this product be out before the next drift event....:top:
I have actually been commented to on YouTube by people that have had spun a bearing, on the clover loops in Dallas. Those aren't that hard of a turn either.
The only form of protection available, until this comes out, is to make sure you have a full 5 quarts of oil in your motor. If you are running 4.5 you are chancinga bad thing.
As long as you fill your oil to the "Full" indicator on the dip stick, it will be at the same level as it is now when full. Just with more oil beneath it. So you won't have to worry about oil hitting our blunt blade cranks.
I'm guessing I have the 4x4 pan. Not only did I look at my pan but I also broke out the manual, again. It says without a oil filter my engine needs 4.9 qt. with an oil filter it needs 5.5 qts. I'm sorry if this isn't relevant but I just wanna know if I need the mod cause if I do count me in!
