Djm install help
Discussion in 'Suspension' started by Xrunner Drifter, Jul 22, 2017.
  1. Xrunner Drifter
    Xrunner Drifter Active Member
    Oct 18, 2008
    1,138
    hey guys
    Im currently in the middle of using the DJM 3/3drop. I installed everything according to the directions and to what advice I saw on here.
    I put new ball joints and new tie rods. Also new struts in the front.
    Went to Sears today to get it aligned, and they told me that my steering knuckle was no good.
    That I needed a dropped knuckle because I put the drop a-arms on.
    They said the numbers were so off that they did not even want to touch it for alignment.
    Please any help is appreciated.
  2. o0opackersfano0o
    Jun 23, 2016
    434
    97
    People at sears are dumb lol. I just put djm in mine and did my own alignment and was able to get everything in no problem. So u have a alignment print out showing how far off it is?
  3. *IrunnIt*
    *IrunnIt* Active Member
    Jan 7, 2010
    2,199
    16
    Try another shop,there shouldn't be a problem getting it into spec
  4. Xrunner Drifter
    Oct 18, 2008
    1,138
    Ok thanks
    That's what I thought
    Question for those who have install djm, the two bottom bolts that hold on the lower ball joint, is there a certain way those are reinstalled? Will that affect the alignment?
  5. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    858
    32
    Tight. Not much to get wrong there. Circle the tires with a string and set your tow with the tie rods to get front wheels square with the back. You should make sure your eccentric bolts are turning free. Alignment shops are lazy and will pass on a job if the won't turn.
  6. Xrunner Drifter
    Oct 18, 2008
    1,138
    When you say eccentric bolts turning free do you mean. I should have them loose for the shop
  7. autobodyX
    Aug 8, 2010
    858
    32
    They have a tendency to seize up. But I forgot you just installed you kit so you don't have that issue. My bad.
    Since you lowered it you probably have negative camber so you could pull the front eccentric in some to correct the camber if you can see the old marks. The rear bolt does the caster use it to set the distance between the front and rear wheels. The need to bee the same. Do this before you set the tow with the string.
  8. Xrunner Drifter
    Oct 18, 2008
    1,138
    Thank you for the help
    I just talked to a guy here at work and he showed me how to adjust the toe.
    And referred me to a shop in San Antonio that specializes in lowered or lifted trucks alignments.
    I will post pictures soon so you guys can see the new truck.
    Thanks for the help
  9. o0opackersfano0o
    Jun 23, 2016
    434
    97
    Wouldn't be able to put the djm arms on if eccentrics were frozen.
  10. Xrunner Drifter
    Oct 18, 2008
    1,138
    Here's another question
    In the kit I did not receive the two pinion angle shims, but directions call that I installed them between the blocks and that leaf springs. So I bought them on eBay and install them on the kit.
    Did y'all install those on your drop?
  11. o0opackersfano0o
    Jun 23, 2016
    434
    97
    I only did front sorry. Did you c notch the frame?
  12. throwinsparksatu
    Nov 8, 2015
    53
    7
    Find a shop with a laser alignment rack it cost per hr but the results are more precise, a lil negative camber is ok
  13. Xrunner Drifter
    Oct 18, 2008
    1,138
    Yes I c-notch the frame
  14. o0opackersfano0o
    Jun 23, 2016
    434
    97
    damn i needs the cnotch part. dont wanna buy the whole kit with blocks and everything
  15. *IrunnIt*
    Jan 7, 2010
    2,199
    16
    Have you tried it with out the notch.
  16. o0opackersfano0o
    Jun 23, 2016
    434
    97
    i have mono leafs and wanna put 2" blocks with it.
  17. *IrunnIt*
    Jan 7, 2010
    2,199
    16
    So 4" overall?
  18. o0opackersfano0o
    Jun 23, 2016
    434
    97
    4.25 total. I did that and axle was hitting frame with low profile bump stops.
  19. markgt531
    markgt531 Active Member
    Mar 27, 2011
    588
    27
    yeh id say look for another shop that could do your alignment. i went to a shop that a member (irunnit) went to , i have the same set up djm 3/4 as him but they said they cudnt do my truck but managed to do his..so id say search.. theres some who will do it, go to a performance shop that likely deals with lowered vehicles, .. not sure why you need the shim for the 3" block you have unless that block isnt tapered. my 4" is tapered for the correct angle so no need for shims... . in the near future im goin to go with 3" blocks... good luck ! keep us posted
  20. Xrunner Drifter
    Oct 18, 2008
    1,138
    Anybody running a pinion angle with a 3inch drop
