Dust shield for BBK (TRD/StopTech)?
Discussion in 'Aftermarket Brakes' started by ChasinCloudz, Sep 2, 2020.
  1. ChasinCloudz
    ChasinCloudz New Member
    Dec 10, 2019
    16
    Hi all! I'm hoping this is the right section for this.
    Been searching everywhere high and low and can't seem to find the answers to this question. For anyone who has, preferably a TRD/StopTech BBK, have you found a straight bolt-on dust shield to go behind the rotors?
    I'm not looking to cut, bend, or remove outright.
    I'm not looking for advice to just remove, cut, or bend. Please, just a simple yes or no, or if you have some resources you can point to.
    I've already checked here, TW, and CT. No luck. Even general google.
    Closest thing I found was the WG > WH, or 14WA (all which are meant for a 6lug). I've cross-referenced the dust shield (Toyota calls them Splash Shields) part number applicabilities between the 2WD and 4WD Tacomas. Both the shield variants (2WD and 4WD) indicate that they work on the 2005-2013 X-Runners. This leads me to believe from the thread on TW about installing Gen5 T4R calipers, the dust shields for the T4R should bolt right up to the hub and have enough clearance for the rotor diameter. My concern here is with the difference in offset.
    Has anyone tried this? Anyone able to verify?
    #1 ChasinCloudz, Sep 2, 2020
  2. NHXRUNNER
    7,943
    281
    I can't say I've seen anyone that has done this successfully yet. I'd love to know if you do come up with a solutions. I removed mine and would love to put something back on since I live on a dirt road.
  3. ChasinCloudz
    Dec 10, 2019
    16
    Yeah. I figured it's been years since people have upgraded their brakes in someway shape and form. But if someone has insight from their own pursuit and wanted to share, this would be the place. I'll list the part numbers here:
    Meant for X-Runner:
    47781-04030
    47782-04030
    Other trims, also listing X-Runner:
    47781-04050
    47782-04050
    14WA conversion:
    47781-60140
    47782-60140
    So to reiterate and clarify in case it wasn't 100% clear in the OP, the basic premise is that all trims of Tacomas are listed for both L/R part numbers under both variants of the dust covers. Which leads me to believe that the 4-bolt mounting pattern between the Tacomas is the same whether 5-lug or 6-lug. For the 6-lug guys, there's a brake upgrade guide to use the 14WA calipers and the dust covers from the 4 Runner. If the new and bigger dust covers mount directly on the hub for the 6-lug, it means it has the same 4-bolt mounting pattern. This should mean that it also fits the X-Runner.
    The TRD brakes came with 332x32mm 2pc rotors and the 14WA conversion for the 6-lug uses 338x32mm. Therefore, the dust cover definitely does clear in diameter. Again, the concern here is the offset difference between the original (X) and converted (14WA) hubs. The dust covers aren't really that expensive. I believe the 4 Runner dust covers run somewhere around $62 each. The pain here would be to separate the hub from the spindle to add these on for fitting. I don't have the TRD/StopTech BBK so there's no way for me to test. If I could get my hands on a set of the TRDs, I'd definitely be trying this. Or if someone's due for a brake job soon and would like to try and contribute here, I think it'll be a good resource for those that want to add the factory designed components back on.
    NHXRUNNER likes this.
  4. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,977
    74
  5. ChasinCloudz
    Dec 10, 2019
    16
    Yeah, I've already seen that. The reason Toyota, or any manufacturer, would say that is because they're not wanting to pay technician labor hours past what is absolutely necessary. Especially here because to change it, you have to separate the hub from the spindle and that takes a LOT more time than simply cutting it off.
    Edit: thought that was the TSB instructions. This is SOS. They say that because, again, it's easier than finding the correct dust shield or custom fabbing one.
