F/I Horsepower and Supporting Mods
Discussion in 'F/I Mods & Tuning' started by hotrodt, May 16, 2012.
  1. hotrodt
    hotrodt New Member
    Apr 28, 2008
    491
    Post you rwhp and mods.
  2. Toon714
    Toon714 New Member
    Jan 29, 2011
    3,637
    custom front mount turbo
    340hp and 377tq@ 6psi :smile:
    will tune for 8psi soon. :blurock:
  3. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    15
    TRD S/C, APR X-1, APR 7th injector, TRD CAI with added hose, DTLT Gen 2, APR Y pipe, URD 3" cat back, full set of NST pullies, URD fuel pump upgrade, 7 1/2 qt oil pan, oem oil cooler.
    354 HP/361 ft-lbs
  4. butters607
    butters607 Active Member
    Oct 3, 2009
    3,826
    Don't know where my dyno is but 451 rwhp and 402 tq with URD mk3 stage 3 system and all supporting kids are in my list
    [​IMG]This image has been resized. Click this bar to view the full image. The original image is sized 1023x540 and weights 98KB.[​IMG]
    well here it is the dyno graph from my run got some nice little curves!
    http://www.xr-underground.com/vb3/showthread.php?t=46308
    #4 butters607, May 16, 2012
  5. Toon714
    Toon714 New Member
    Jan 29, 2011
    3,637
    i will be up in the 500 range real soon......:wink:
    only if my master plan plans out. :smile:
  6. Whitebeauty
    Whitebeauty New Member
    Oct 15, 2011
    5,237
    Oh i like the sounds of that!
  7. Moneyblind
    Moneyblind New Member
    Mar 25, 2012
    1,067
    *drools* :blurock:
  8. Whitebeauty
    Oct 15, 2011
    5,237
    Would love to see some pics of your swap...
  9. hotrodt
    hotrodt New Member
    Apr 28, 2008
    491
    Look up my build thread. Its under "it has began hotrodts ls1 swap
  10. sixstringdave
    sixstringdave Member
    Jun 10, 2009
    939
    Just did another dyno tune last week, but i think i need to go to another shop next time. I have seen people on here(with my same mods) say they are in the 250plus range. I am only in the 240-ish range. 241 HP is the best i have seen.
    Some have posted the same numbers for HP as me, but they are getting like 290-ish torque. I am sitting right around 270-ish. 276 lbs. is the best i have seen.
    I am guessing another shop that knows Toyota a bit better may be what i need???
    Supporting mods are up and to the right!
  11. Torspd
    51
    Could be the type of dyno used as well as the type of correction factor. Climate and altitude will also play significant roles.
    Also, here is a base dyno, for point of reference:
    Stock XR - 191.7 WHP 231.6 WTQ
    (base dyno from Scoutdeed69):
    http://www.xr-underground.com/vb3/showthread.php?t=49762
    [​IMG]This image has been resized. Click this bar to view the full image. The original image is sized 1023x612 and weights 138KB.[​IMG]
    [​IMG]This image has been resized. Click this bar to view the full image. The original image is sized 1023x612 and weights 192KB.[​IMG]
    #11 Torspd, May 17, 2012
  12. sixstringdave
    Jun 10, 2009
    939
    Its an old Mustang Dynojet or something like that. Thats what they tell me anyways. Just seems like i should be in that 250+ HP and 290+lbs. range.???
    EDIT: Also, i am almost at sea level and it was about 70-ish degrees in the shop.
  13. butters607
    Oct 3, 2009
    3,826
    It's not up to date put some more info out!
  14. Torspd
    51
    Mustang Dynos read a little lower than Dynojet. Mainly in the lower HP range.
    You have a bunch of "kids" running your engine? :laugh:
    #14 Torspd, May 17, 2012
  15. hotrodt
    hotrodt New Member
    Apr 28, 2008
    491
    Dyno numbers don't really mean crap....where it counts is at the track and your kill list.....time slips is where is at....
    I know its not up to date....that was for the noobs wanting to see pics of swap....a lot of ppl don't know the build thread exist .lol. Only a couple of changes have been mad since I finished. I'm getting back underway....heads n02 and whipple sc coming soon.
    #15 hotrodt, May 17, 2012
  16. WallasX
    WallasX Active Member
    Mar 14, 2008
    1,140
    448 hrpw
    406 trq
    Here is my new dyno. I got a new special tune from gadget last weekend. My current set up is a URD MK 2 STAGE 2
    [​IMG]This image has been resized. Click this bar to view the full image. The original image is sized 1024x576 and weights 79KB.[​IMG]
    just so everyone knows ever line to the right is 1000 rpms the last line the dyno makes it to is 6000 RPM
    MK 2 stage 2, 10 psi
    Dtlh, URD y pipe and exhaust, x-1 with special tune from G man.
    #16 WallasX, May 17, 2012
  17. sixstringdave
    Jun 10, 2009
    939
    I agree for the most part, but it gives me an idea if my truck is running like it should. I dont really race anyone on the streets anymore and i only go to the track maybe once or twice a year. Shooting over to the dyno shop has really helped me with the pig rich problem i was having. Even though i was "beating" guys at the track or on the street i had no idea i was running so rich. So by getting results on a machine i was able to tune it and squeeze even more HP from the truck while safely leaning it out..
    I can see why a guy with an ls1 prolly doesnt care about his numbers :rockon:
  18. X-roller
    X-roller Active Member
    Sep 6, 2008
    5,447
    1 horsepower supporting mods... a horse..
  19. hotrodt
    hotrodt New Member
    Apr 28, 2008
    491
    I'm still goin to get it dynoed just for numbers...street tune is always better...you cause your actually pushing weight of truck not a 3000lb Dyno drum. I still want a sheet with pretty lily torque curve for bragging rights....can't wait to spinher to 7k
  20. blackx-runner
    blackx-runner "White Flash"
    7,581
    13
    415 HP, 390 TQ. URD MKII stage III with the C38-71 blower.
