SignUp Now!Agreed, but it wouldn't reduce heat soaking or act as a ram air so I really don't see the advantage of it.
Most fender well intakes breath at or damn near ambient in motion.
I just dont see the need to re-engineer the wheel / introduce more complications in the process for near identical outcome.
To be honest I like coupe's idea better lol.
I'm still waiting for any evidence to surface that proves it won't act as a ram air. :biggrin:
There really isn't a need. Except it would add a few extra HP and be cool to have a fully functional scoop.
I mean you could drop an intake under the front bumper if you wanted too.
It's all a matter of personal choice. I think it would be awesome, if it takes a little more effort, so be it. It would make it that much more unique.
Kinda like going for Airbags instead of a standard drop. They both achive the same outcome, one just take more to install lol.
Oh and Kudo's to coupe for doing that too. It's a good idea.
Just for me I like the idea of having a fully functional Hood scoop.
I came close to making the hood scoop functional. In the end, I convinced myself the air around the scoop would be "dead". The air may flow over the scoop, but not within.
My opinion.
I could probably make a kit to make the factory scoop functional, but it would be expensive.
I wonder how much it would cost coupe...:hmmmm2: is the $400-500 range sound about right...?
I dont see the point in doing this.
The truck is designed to have air flowing over the scoop. Not into it
but look at the hood scoop on the subarus, aside from the massive scoop on the WRX STi, most of theirs are pretty small and yet are still fully functional, so why shouldn't ours be able to work that way, all it would take is a TRD or AFe intake that has the filter in a box with a open top, then just route the air over to the top and use a piece of weather strip to seal when the hood is closed. if i get a CF hood and a TRD intake, this is deff on my mod list.
dude with the blue taco has gotthe right idea but it will funnel water and everything else... thats where my idea would come into play. maybe a mixture of the 2 and we would be on to something. what you guys think?
The question is not whether the scoop gets air or not - it will get air. The real question is does the scoop get any RAM air. Unfortunately, the Xrunner scoop does not stand off of the hood, and therefore probably only "sees" boundary layer flow (or mostly boundary layer flow).
Bottom line: cut your scoop open and you will get airflow but it will most likely be static airflow. The point in a hood scoop is usually to get RAM air benefit (higher inlet pressure), but a scoop that lies almost entirely in the boundary layer doesn't provide any RAM benefit.
For example, google the WRX STI and note that the hood scoop stands off the hood a bit (especially the older models). This diverts the boundary layer flow under/around the scoop inlet and the scoop receives RAM air.
Another example, google a picture of the F-18 hornet and look at the engine inlet... it also stands off the aircraft fuselage to divert the boundary layer. This might be the extreme example, but the same physics apply only at higher speeds.
Wikipedia has a decent explanation of what is boundary layer.
^^^^where have you been?
