Gauge power source
Discussion in 'Interior Modifications' started by NHXRUNNER, Apr 26, 2016.
  1. NHXRUNNER
    7,870
    253
    So I picked up a couple gauges and a Flexpod for the truck and want to know where everyone tapped power from. The install guide calls for a 12v switched power. Whatcha got for me?
  2. Venomous_X
    Venomous_X Active Member
    May 11, 2008
    13,694
  3. NHXRUNNER
    7,870
    253
    Thanks Donny, got a suggestion to use an add-a-circuit on the rear power windows circuit. I saw that one of the old How To threads suggested the same teal white wire...
  4. Venomous_X
    May 11, 2008
    13,694
    I'm glad you asked LOL... I ended up browsing some of the old threads and started reminiscing brother. Hope things have been good.:top:
  5. fishsticks
    fishsticks Because fast lifted truck.
    Nov 29, 2015
    207
    7
    I have a relayed circuit that is triggered off the EFI fuse in the engine bay that I use for key-on auxiliary stuff.
  6. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    I installed a 2nd fuse box and ran a dedicated circuit.
    Who in the hell is Venomous X???????
  7. 30Birdy
    30Birdy Member
    May 3, 2015
    281
    21
    This is the safest option. With the Ebay ones, it will give you 3 other circuits to add as well.
  8. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,766
    13
    Since you're right there at the steering column I'd just grab power from the ignition harness. I can't remember colors, but there are 2 seperate ignition switched wires. One will lose power while cranking the truck. One will keep power while cranking the truck. This is the one you want to use in case your gauges have a start up sequence, so they won't re start every time you hit the starter.
    You're just powering gauges, no need to over complicate it. Just add a 5 amp in line fuse. The wiring in the ignition harness is heavy gauge stuff and won't be affected by some gauges running off of it.
    #8 justin13703, Apr 26, 2016
  9. Venomous_X
    May 11, 2008
    13,694
    White with teal tracer is ignition source that stays on during crank. :crinklehair:
    James.... I am but a figment of your imagination LOL Howdy do?:biggrin:
  10. justin13703
    Sep 9, 2010
    2,766
    13
    Thank you sir :top:
    There you go. I'd just tap into the white/teal at the ignition harness, add the inline fuse and call it a day.
  11. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    858
    32
    Good information. I have had a flex pod for a year now and if I make up my mind on what gauges to buy I can get them installed.
    I keep waiting on the new version of the UCON it can wyfye to a multi gauge display.
  12. hottacoX
    hottacoX Moderator
    Dec 21, 2009
    4,823
    I used the add a circuit off the rear window fuse since our trucks don't need em
  13. hottacoX
    hottacoX Moderator
    Dec 21, 2009
    4,823
    I daisy chained all my gauges off that with the exception of the Widenand sensor, I put it on its own deadicated fuse.
  14. Slywhitty
    Slywhitty "Midget Magnet"
    Jan 26, 2008
    3,393
    Pretty sure that's the same spot I tied mine into. Can't remember though. Just remember using a test light and found one empty slot that had power at key on lol
  15. NHXRUNNER
    7,870
    253
    I've only got 2 gauges so I think I'm going to run them both off the add-a-circuit.
    Now that we've got the power source out of the way. Anyone else have the Flexpod? I installed mine and the bracket scrapes the damn steering wheel.
  16. fishsticks
    Nov 29, 2015
    207
    7
    Mine clears the steering wheel. I had to run a tap down the holes for the socket head screws, as you couldn't tighten them down with the powder coat on there. Also the Innovate gauge bezels bind pretty bad at the hinge point, and my column screws were silver instead of the oxidized black shown in the pictures.
    Neat idea, but at $120 for a couple pieces of aluminum I expected better finish work.
