Going back to stock
Discussion in 'Stock Performance/Mechanical' started by na-mr2, May 12, 2017.
  1. na-mr2
    na-mr2 Member
    May 12, 2017
    65
    Hello all this is my first post here. I just purchased an 06 X Runner with 52k. It has some mods and the check engine light is on. I took the gamble and. Bought it. Mods are as follows
    Doug Thorley long tube headers
    Magnaflow ss catback
    URD cold air
    NST light weight pullies
    URD map Ecu
    URD O2 stimulators
    URD short throw
    Oil pressure and oil temp gauges
    And a few other things.
    Previous owner told me about the light coming on. I drove it home with the light on and ran fine. I cleared the codes and started it only to have the light flashing and it was sluggish. Turned off and started it again and it ran fine but the light is constant on. I don't care about the mods. I have no issues going back to stock. I have all the parts except the air box. The codes are p0300, p0303, p0305, p0174. Any thoughts?
  2. o0opackersfano0o
    Jun 23, 2016
    387
    80
    Kinda weird codes. 300 is random misfire. 303 is misfire on cylinder 3 and 305 is misfire on cylinder 5. 1,3,5 are on bank 1. Your 174 is lean on bank 2.
  3. na-mr2
    na-mr2 Member
    May 12, 2017
    65
    So I spoke to the previous owner. He never had an issue with a code prior to the headers, intake or the maf calibrator. I didn't ask if he changed any plugs or coils. I'm not a mechanic by any means which is why I'm here. I'm ready to get it back to stick and start from there and sell all the performance parts
  4. SgtBadA
    SgtBadA Active Member
    Apr 21, 2013
    583
    33
    I say take off the maf calibrator and see what happens. I've been running long tube headers for 3 years now and haven't had an issue yet. I would venture a guess that either the maf sensor is bad or that calibrator is jacking up your signal readings to the computer
  5. na-mr2
    na-mr2 Member
    May 12, 2017
    65
    Either would give a misfire code? I'm not a mechanic so sorry if it's a dumb question
  6. C10Ben
    C10Ben New Member
    May 8, 2017
    29
    I just bought my 2008 x runner last week with 107k miles . I had random multiple misfire . Cylinder 2 misfire . Cylinder 4 misfire . Passenger side is reading lean . Drivers side is reading rich .... runs fine off idle . A little shaky at idle but nothing to bad ...... the other day. I lost all power and check engine started flashing ..... I ended up replacing the three injectors on bank 2 .... since then I haven't had a misfire code come back . But I'm still getting lean passenger bank . Rich drivers side . I have compression and Fire . I'm. Thinking the vvt is sticking and has my timing stuck advanced on the drivers bank and that's why it's rich. I'm going to replace the vvt solenoids . Will let you know if this changes anything
  7. na-mr2
    na-mr2 Member
    May 12, 2017
    65
    I have had it idle low and alittle stuttering to. Yesterday I took it out and it was misfiring crazy. Sounded like and old ford. Keep me posted please. I'll be dropping it off at the shop in a week so I'll wait to hear what your results are
  8. o0opackersfano0o
    Jun 23, 2016
    387
    80
    Ya best bet is to have it looked at. I could help u if u were local. Just gotta swap around plugs, coils, Injectors. And I don't think the maf cal has anything to do with it or else it would be lean on both banks not just one.
    C10Ben likes this.
  9. C10Ben
    C10Ben New Member
    May 8, 2017
    29
    I'm a fully certified mechanic . The vvt. Is arriving Wednesday . If it does not fix the problem . I will be pulling the front cover to
    Inspect. The timing chain to make sure it's not a tooth off . Or the guides and tensioner are performing properly . I WILL find the problem . Lol . And will def keep the forum posted
  10. na-mr2
    na-mr2 Member
    May 12, 2017
    65
    Considering mine only has 52k I doubt that would be an issue for me. Then again, I'm. It a mechanic. But I will be waiting for your diagnosis
  11. o0opackersfano0o
    Jun 23, 2016
    387
    80
    Usually if the timing is off you can a cam crank correlation code. I've seen it happen on fj's. The chain actually stretches. Dunno why only on fj's
    C10Ben likes this.
  12. SgtBadA
    Apr 21, 2013
    583
    33
    Fj cruisers have dual VVT. I think that's how the chain stretches. As for the po300 code that's a random misfire not isolated to a single cylinder. That maf calibrator if it went bad it could make the engine run way to lean and cause the misfire. That's why I say remove it and see if that changes anything
  13. C10Ben
    C10Ben New Member
    May 8, 2017
    29
    You are right . And I haven't gotten and. Crank/ cam correlations on this . But It did read cylinder 2-4-6 misfire . I wanna check the cam phaser at the very least . See if it's gummed up . Hoping the previous owner was as anal about his oil changes as I am
  14. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    I would do this first than anything else.
  15. na-mr2
    na-mr2 Member
    May 12, 2017
    65
    The previous owner did all the install himself and said the calibrator was difficult for him to install. From what you guys are saying I'll guess he mixed a wire or two. He said he didn't have the cel light on till after that and the intake and exhaust.
  16. Slywhitty
    Slywhitty "Midget Magnet"
    Jan 26, 2008
    3,385
    7
    Have you talked to @Gadget about these issues? I'm sure he could lead you in the right direction!
    Gadget likes this.
  17. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    837
    27
    How about doing a plug check or change? Recomended service on them is 30,000 miles. Then I would swap the two aid fuel sensors and see if it codes the same or switches sides.
  18. na-mr2
    na-mr2 Member
    May 12, 2017
    65
    I haven't reached out to gadget yet. I'm ode to this site so I'm learning where to get advice
  19. Slywhitty
    Jan 26, 2008
    3,385
    7
    Well he is URD. So he's the man to ask about issues with urd stuff!! Good luck getting it all sorted out!
  20. wolfpack_5150
    wolfpack_5150 Jangley
    Jan 13, 2012
    303
    17
    And what happend?
