Bulldogger
- Oct 30, 2011
- 616
Coming from other boosted applications I assumed we would be talking about good tuning. Next knock shouldn't be that big of an issue if the timing isn't pushed along with boost levels. I wasn't interested in how much horsepower the truck can make more along the lines of how much boost the rods and ringlands can handle. If I know the boost level then I can make adjustments from there. I have a tendency to work things backwards. My GT500 can run on race fuel but I don't choose to go that route. Anything at or over 18lbs really is cam 2 territory. I choose my VMP TVS based on the fact that it makes just under 18lbs actually about 17.5 on stock exhaust. Throw on Dynatech LT's and catless pipes, I am at 16lbs of boost, with a 17* of timing and 93 octane I am still in a conservative safe area, with 680 rwhp.
As far as which route I will go TRD will more then likely be the more difficult route as far as cooling the IAT and getting parts for it, but the reflash ECM can't die independently causing issues, like a piggy back system. My experience having both is twin screws/roots are more fun stop light to stop light but suffer form heat soak and fall off up top. Centrifugal can lack a litlle out of the hole but are alot less prone to heat soaking and do much better up top. Plus URD seems to have everything in one spot shopping which is nice.
X-roller he doesn't list any supercharger options with his kit. What changes he has made in the past well I lost my crystal ball. Searching this forum and the URD site only seemed to show the MKII units with different stage upgrades, like stage I to II to III. All head units are the same on his web page. When you do other boosted cars there are alot more options on head units. Example GT500 you can run a TVS 2.3l or a whipple 2.9 or 3.4 or 4.0, you can also run KB 2.8 2.8l or 3.6 plus fords version of the TVS eaton.
