- Jul 30, 2007
- 8,001
- 305
This is a how-to for installing the Lightsource HID Reverse kit into NON-LED tacoma tail lights.
Here's what comes with the kit.
Remove the tail lights
Top bolt
Bottom bolt
Pull straight back on the housing to pop these two pins out. Be sure not to pull towards that fender to avoid damaging it.
Disconnect the wiring harness
Install bulbs in housing
Remove reverse bulb
This is the reverse bulb socket
This is the Lightsource harness and the OEM reverse bulb
Insert harness into reverse bulb socket. Be sure the contacts make good connection within the socket.
This is the bulb (DO NOT TOUCH THE GLASS!!)
Slide the bulb out of the rubber boot
Carefully insert the bulb into the housing. Try not to make contact.
Stuff the boot into the housing.
Gently pull the wires to slide the bulb back into the rubber boot.
Final product, bulb installed.
Mount the ballast
Apply adhesive, or hook and loop fastener to the ballast
Mount ballast to inner fender.
Make final connections
Connect ballast to reverse harness
Connect ballast to bulb
All that's left is to re-install the housing in reverse of the steps above.
Here's what they look like in OEM housings.
Top bolt
Bottom bolt
Remove reverse bulb
Mount the ballast
