How to upgrade your diff
Discussion in 'N/A Mods & Tuning' started by Nashman, Nov 23, 2015.
  1. Nashman
    Nashman Active Member
    Oct 22, 2015
    425
    28
    When I first bought this truck I liked how it felt but found the rear lsd diff to be some what lazy, so I did some digging and found upgrades for it by calling up wier performance to see if they made a kit for our truck since our lsd is pretty much the same diff found in the mk3 supra 86 to 92.
    So I paid for the kit which came to 45 bucks
    I all so found another upgrade for our diffs as well form yokon
    https://www.yukongear.com/productdetails.aspx?ProdID=4850
    So some may ask is it worth upgrading the stock diff instead of buying a aftermarket lsd? is our lsd stroung ? Well the answer is yes our diff are very strong the casing will take 1000 plus hores power and not even wink as for the ring and pinon well thats the down fall of any 8 inch toyota diff and well ya cant really fix that.
    The best part about our diff it's it's pretty much the first gen tundra diff and has joined baring caps to make the diff even more ridged to stop it front twisting under load.
    OK lets get down to the tools you need to installed this kit
    - Dail gauge
    - basic socket set
    - micrometer
    - felt pen
    - automatic punch or a punch and hammer
    - paint pen
    diff Oil
    80/90 none syntactic oil preferred but I figure once I find it I will swap to 75/90
    or if you want a smoother diff then just run synthetic oil like Redline 75/90
    lsd addtive
    ford
    yokon gear
    ac delco stuff is gargbage
    so drive you truck on the hoist or jack up the rear end in the drive way
    clamp the soft brake line with vise grips or line pinching tool undo the brake line fitting then remove 2 bolts that hold the e-brake cable down then the 4 14 mill nuts that hold the axle in and then just pull the axle out
    next un bolt your drive shaft from the diff and push it aside and then un bolt you diff and pull it out
    Now the fun part keeping every thing in order
    I used a white paint pen to mark the one side of the diff showing which side goes were you do not want to mix these up because you back lash will be off.
    now it time to mark the case and then pinon for the spider gear so you know wich way then go it is best to use a punch for this one mark close to the top of the pin then one on the case
    un due the carrier bolts and then take the diff apart and keep the plates in order and all ways keep the one clutch that has one blank side and one textured side on the case side this is what toyota used to shim the diff from the factory
    once it is all apart you have the option on glass beading the stock coating off if you want a smoother diff might be an idea to leave it on but it does were out fast I chose to remove it so my spider gear back lash will not change as fast
    next we start to shim the clutch pack and mic out all the shims
    it best to start off with the thickest shim and go from there and then put your clutch pack in the lsd unit and pop in you spider gear assembly then setup your dail gauge and then rock one of the spider gears with you finger and see what back lash you have and add from there. I ran 20 in stead of the 005 target mostly because I ran out of shims and still way tighter then stock. ps may be good idea to ask wes to add more shim's to the kit if you plan to remove the coating. Ps you have to make sure you clean off all the oil or it will mess with your measure ment
    then all ya do if repeat this on the other clutch pack
    now ya just have to put it together just remmber the spring retainer plates go only one way and try to miss aline the retainer pins
    pop in the new helper spring
    slip on the plate and aline the pins and then place up cap on the diff to put it together then use to clamps to slowly clamp the case together wail making sure the pins are lined up
    then torq the retainer bolts to 35 foot pounds
    then use a dead blow to tap the shims back in
    then tap on the carrie cap I useded 2 dead blows because well one just was not doing it because I was rocking it back and forth with just the one and I am sorry I forgot the bolt torq spec i will have to look that up at work
    and there you have it a new better then stock diff that you will just love
    ps it's best to use half the bottle of lsd additive when you first break in the new diff if you choosed to remove the coating you will not have to find a place to drive in figure 8 for about 1/2 and hour at about 30 km then after that drain the oil and then add the rest of the bottle and then enjoy
    warning the diff will clunk abit for awail tell it break's in this is normal if you don't like the clunk you can just run synthetic oil this should make it clunk less
    I may dump my fuild out that i have right now but my clunk is going away.
    well i know there has got to be about billion spelling grammar mistakes but all fix thosu later and add to the write up cheers for now
    #1 Nashman, Nov 23, 2015
  2. x-runner kid
    x-runner kid Active Member
    Oct 11, 2007
    1,346
    21
    That's an awesome write up. I still don't know how confident I am in doing this myself though lol.
  3. shane881510
    shane881510 Active Member
    Feb 14, 2010
    875
    32
    Yea awesome write up. U made it sound Easyer than I know it is.
  4. Nashman
    Oct 22, 2015
    425
    28
    It's pretty easy took me about 2 hours for a frist timer much more but it's not very hard to do. No if you had to re do your back lash or replace Pinon that take longer becase you have to make a jig up or buy one
  5. x-runner kid
    Oct 11, 2007
    1,346
    21
    Hmm if I decide to try this and I get it all apart and can't put it back together I'll send it to you haha.
  6. x-runner kid
    Oct 11, 2007
    1,346
    21
    I tempted to do the Yukon upgraded plates though. Although it says on the site it's for aftermarket eaton positraction only.
  7. Nashman
    Oct 22, 2015
    425
    28
    ya i saw that but kinda does not make sense I think it's best to call them and fully confirm
    if not leaving the coating on will be fine
    the big issue is the stock spring is fairly weak and the clearnce in the spider is way way to much and make for a fair bit of play
    further more after Christmas i going to try to swap in some synthetic oil like I did in my other truck what is metal on metal plates
  8. x-runner kid
    Oct 11, 2007
    1,346
    21
    Ya I would Def call them before I went that route. I just wonder how worn my friction plates are at 118k
  9. Nashman
    Oct 22, 2015
    425
    28
    fine just the coating might be a little worn that's all really
  10. x-runner kid
    Oct 11, 2007
    1,346
    21
    You think just a spring and shim kit without blasting would be ok then? I'm a noob when it comes to diffs but I'm very mechanically savy.
  11. Nashman
    Oct 22, 2015
    425
    28
    Sure just grabs more with the coatings off
  12. x-runner kid
    Oct 11, 2007
    1,346
    21
    Ah good to know. Need to drop my trans first this will be next on my to do list.
  13. Nashman
    Oct 22, 2015
    425
    28
    whats wrong with trans
  14. x-runner kid
    Oct 11, 2007
    1,346
    21
    Oh I somehow got a faulty throwout bearing upgrade. So gadget hooked me up with a new one. The other one lasted maybe 2k. I figure when I'm in there I'll put in a new clutch release fork also just as cheap insurance.
  15. Nashman
    Oct 22, 2015
    425
    28
    Oh i see but diff is well broken in now i truly love it
  16. x-runner kid
    Oct 11, 2007
    1,346
    21
    No more clunk then?
  17. Nashman
    Oct 22, 2015
    425
    28
    only when cold it will go away fully soon ....even if it felt clunky i still live with it because stock setup is garbage
  18. x-runner kid
    Oct 11, 2007
    1,346
    21
    Too bad your no closer I would bring you mine to do haha.
  19. shane881510
    Feb 14, 2010
    875
    32
    Im looking into doing this to my lsd. And was wondering if the stage 2 kit with the spring plates and spacer would work on our diffs and whats ur breakaway torq right now on ur truck.
  20. Nashman
    Oct 22, 2015
    425
    28
    just call him ask for more shims if you plan to blast your plates mine is aggressive if ya want it abit less aggressive run the coating or blast them and run synthetic oil if you find it to much
    I truly love my diff makes my truck so much fun to drive and no second guessing ever
