How to upgrade your diff
Discussion in 'N/A Mods & Tuning' started by Nashman, Nov 23, 2015.
  1. MiamiChillin
    MiamiChillin Member
    May 30, 2015
    212
    Nice write up man. Dont know if I should tackle this on my own lol.
  2. Redlantern
    Redlantern Member
    Jan 28, 2013
    526
    6
    You guys happen to know if the LSD from the xrunners and the LSD in the Tacoma sport are the same? I just picked up a rear end off an 07 sport Tacoma that has an LSD on it. Will be switching it out with the one I have on there nowadays would like to do this mod if compatible.
  3. x-runner kid
    x-runner kid Active Member
    Oct 11, 2007
    1,346
    21
    What year is the sport you got it out of?
  4. Redlantern
    Redlantern Member
    Jan 28, 2013
    526
    6
    Came from a 2007. I spun it to make sure it's a true LSD and both sides spin in the same direction.
  5. x-runner kid
    Oct 11, 2007
    1,346
    21
    Should be the same thing then.
  6. Nashman
    Nashman Active Member
    Oct 22, 2015
    426
    28
    you may have to swap the lsd unit out since I figure it will have different gear ratio
  7. Redlantern
    Redlantern Member
    Jan 28, 2013
    526
    6
    makes sense. Damn i have the 3.73. i believe xr's have 3.15. Its ok, if it ever blows i'll just invest in a detroit locker.
  8. Nashman
    Oct 22, 2015
    426
    28
    just re use you ring gear and stuff its the same
  9. Xcars_onfireR
    Xcars_onfireR Member
    Mar 21, 2012
    242
    I just pulled apart my diff to re shim the clutch pack and it brought it right back to new. I'd like to get one of he helper springs you got to give it a little more bite. But I'm supper happy to be spinning two tires again!! It really wasn't that hard or time consuming to do either
    A tip to anyone pulling their rear diff out use a bar or peddle depressor against the seat to push the brake peddle down a bit. That will close off the ports in the master and stop all your brake fluid from ending up on the floor without having to crush your flex lines.
  10. Nashman
    Oct 22, 2015
    426
    28
    takes longer to bleed and once ya release pedal just suck in more air up the lines
  11. shane881510
    shane881510 Active Member
    Feb 14, 2010
    875
    32
    Nash man I was looking at the stage two lsd kit from wier and will it work on our rear end. It removes the spring and use disk springs and a spacer
  12. Nashman
    Oct 22, 2015
    426
    28
    I have installed that kit she is nasty as hell very aggressive for a truck's light rear end
    was not to bad in the supra thou
    but to answer you questions yes it's the same pretty much
    simply put it's a drift diff or a truck with big tires
    just went auto crossing on Sunday and the diff worked out so well in the dry this is my first really dry event that I got to push the truck
    stage one is what I recommend
  13. shane881510
    Feb 14, 2010
    875
    32
    I do a lot drag racing I need them to lock up good. I run 295 or bigger tire.
  14. Nashman
    Oct 22, 2015
    426
    28
    Still no point the stage 1 will still grab just as good at stage 2 it's a clucht pack it's a 2 way lsd factory so there is no delay in lock up
    It's not a torsen or viscous so no need to worry she will always go straight pending on tire pressure being =
  15. shane881510
    Feb 14, 2010
    875
    32
    I just ordered the stage 1 and nervous about installing it. U made it
    Look to easy.
  16. x-runner kid
    Oct 11, 2007
    1,346
    21
    Let us know how it goes since I have been waiting for another brave soul to try it before I take the plunge
  17. Nashman
    Oct 22, 2015
    426
    28
    you will be fine just don't miss aline the retainer pins if you do you will snap the plate
  18. shane881510
    Feb 14, 2010
    875
    32
    Well I'm done with the LSD. Just gotta put it back in the rear end and slide the axels back in. Wasn't as bad as I figured. My plates pretty much had no coating left to get off so. It's nice an tight now. Only advice I can give to make it Easyer is to make sure u line up the spring plate pins. Them sum b are tricky as f. That's the only thing I ran into that gave me a hard time. I broke one side of the long ones. Had to knock it out and replace it. But in the end everything came out good. I can't wait to get it back together. Two side by side black marks can't wait
  19. Nashman
    Oct 22, 2015
    426
    28
    oh and you forgot wheel hop
  20. shane881510
    Feb 14, 2010
    875
    32
    No sir, I don't have wheel hop. I have a trac bar.
