How to upgrade your diff
Discussion in 'N/A Mods & Tuning' started by Nashman, Nov 23, 2015.
  1. Nashman
    Nashman Active Member
    Oct 22, 2015
    426
    28
    Well look at you mister fancy pants haha
  2. shane881510
    shane881510 Active Member
    Feb 14, 2010
    875
    32
    I built it myself only costed like 100 something
  3. Nashman
    Oct 22, 2015
    426
    28
    Is it made of wood
    maybe pine or is it a hard wood ?
  4. shane881510
    Feb 14, 2010
    875
    32
    No 1 1/2" steel tubing and three bars ends with poly bushings with an adjustment on the bottem. It's like urds but all welded on brackets and a little shorter. I need to get a pic of it.
  5. Nashman
    Oct 22, 2015
    426
    28
    Ya i want to build one but stock class in auto cross will not let me
  6. shane881510
    Feb 14, 2010
    875
    32
    Yea that sucks. Traction bars should be allowed in all classes.
  7. x-runner kid
    x-runner kid Active Member
    Oct 11, 2007
    1,346
    21
    Does anyone know what all the torque specs are for all the bolts? I know the ones are 35fl-lbs but don't know the others.
  8. Nashman
    Oct 22, 2015
    426
    28
    tight lol with out shop key I don't know think i may have said it in one of my post or wrote it on the gear or something
    the main cap bolts is the only one you need
    (((((correction 70 foot pounds ))))) google told me that for both ring gear and main caps
    #48 Nashman, Feb 20, 2017
  9. Nashman
    Oct 22, 2015
    426
    28
    oh and add red lock tight to the ring gear bolts and if useing it drop your torq 10 pounds
    i not sure if i used red lock tight with this install B i used to use it on toyota 8 inc spilne cone adjuster they deflected alot
    the Tacoma diff is alot more robust with it's griddle caps
    #49 Nashman, Feb 20, 2017
  10. x-runner kid
    Oct 11, 2007
    1,346
    21
    Awesome I found another source on like tacoma world or something that had 63ft-lbs for the caps but I said fuck it and did 70ft-lbs. it's all back together just waiting on my new seal for the housing and it's all done. Wasn't nearly as bad as I thought. The hardest part was wiping the oil off the clutch discs to get my lash set. Only needed the heaviest and lightest shins. Got mine down to 005 like my goal. Left the coating (what was left of it) on the clutches as well. The pins were not very easy either but I have a lot of patience and got them lined up pretty easy. Whole process took me about 2 hours of just taking apart and getting the diff shimmed and torqued back down. Thank you very much for the write up Nashman. Can't wait to have my rear locking up like it should be!
  11. Nashman
    Oct 22, 2015
    426
    28
    Good to hear buddy you will love it
    x-runner kid likes this.
  12. blackote
    blackote Member
    Sep 27, 2009
    46
    9
    Ressurecting an old post, but found this to be my next mod.. How is everyones kits holding up so far?
  13. Nashman
    Oct 22, 2015
    426
    28
    mines still doing a great job and is much smoother now that is fully broken in i did switch to to redline rear diff fulid as well to give ti a try do far i like it
  14. blackote
    blackote Member
    Sep 27, 2009
    46
    9
    Been trying to get a hold of Weir Performance to order the kit but havent had any luck so far... Just did the Tundra/ISF upgrade on my brakes... So this upgrade is now top priority
  15. blackote
    blackote Member
    Sep 27, 2009
    46
    9
    Just placed my order today with WP, said the kit should be in before the weekend. Just to clarify, the shims are placed together where the stock adjusting shims are located (between differential case housing and thrust washer) adding to the thickness correct? You dont shim between the side gear/side thrustwasher?
  16. Nashman
    Oct 22, 2015
    426
    28
    correct it's just like stock it's just tighter so it reacts faster then oem mine is on the loose side but still far tighter then oem spec's because I sand blasted my packs for a better bite
  17. blackote
    blackote Member
    Sep 27, 2009
    46
    9
    Sounds good.. im really excited to put this in, i think after this mod will be the traction bar... it would be best to do it at the same time, but knowing how i am i wont be able to wait
  18. Nashman
    Oct 22, 2015
    426
    28
    i have the urd track bar and my truck still hops a fair bit in the rain
  19. blackote
    blackote Member
    Sep 27, 2009
    46
    9
    received my kit and will attempt to install it this weekend. For those that have done this mod, has everyones gear mesh and backlash measured out the same from prior to the install? Thats the only thing that is kinda worrying me with this. I know it would be best to keep everything in accordance with its initial install I.E. left side / right side. I was leaning towards installing the shims myself and then having a shop reinstall the LSD into the 3rd member just to make sure gear pattern is good. So far it looks like 3 others in this thread have success so maybe I wont need to take the 3rd member to anyone as long as I reinstall everything where it belongs
  20. blackote
    blackote Member
    Sep 27, 2009
    46
    9
    Just finished the install... wasnt bad as i thought... it definitely reminds me of my 240sx back when i installed a 2way. Thanks Nashman for the write up!
    Never again will i do this on a driveway hahaha.. i think it would be easier using a lift.
