huge failure
Discussion in 'Stock Performance/Mechanical' started by Toyotaguy_7, Dec 14, 2009.
Tags:
  1. Toyotaguy_7
    Toyotaguy_7 New Member
    Aug 22, 2007
    951
    help in Iraq my truck at home alone in the cold with dash lights on low tire pressure light, cel, brake, abs plus the a/c light flashes what the H is going on here need input please.
  2. KETCHUP
    KETCHUP Active Member
    Nov 1, 2007
    11,665
    wow, that doesn't sound good. do you have a scan guage II? If not, auto zone can do a scan on the code. I would have someone disconnect the battery. Leave it for a few and then reconnect. That will re-set the computer. Has it been sittin for a while, or has someone been driving it?
    hypertaco likes this.
  3. SX TOY
    SX TOY Active Member
    May 23, 2009
    1,965
    is there a local e mail or phone # of someone that can walk through the problem.
    there are a few questions to ask.
    it is cold so it could be as simple as cleaning the battery posts and charging it.
    did it stall/die and not start back up or will it just not start?
    ac flashing could be a secondary prob
  4. ntinhri
    ntinhri Active Member
    Feb 1, 2007
    8,104
    How olds the battery? How cold has it been, low battery will cause nasty things to happen. I'd check the battery with volt meter. Also unhook the battery for 30 - 60 seconds and try to honk the horn while its unpluged. Hook it back up and see what happends. I assume some one elses is driven ur truck while ur away, I'd ask them if they ran over any thing that they know of. Maybe the ac power wire has come loose and flying around causen it to flash as it makes contact. Also check the codes. If there is a code, we can help much more!!
  5. lamecargo
    lamecargo Active Member
    Sep 15, 2007
    1,306
    Now turn the key a little more.........:dontknow:.......JK but that does sound nasty
  6. Toyotaguy_7
    Aug 22, 2007
    951
    thank you much i'll get to them the battery 2 plus yrs with sub running off it for the whole time. been cold enough for ice. when you hit the a/c button it quits flashing for a little. it's throwing o2 code might because of the simulator? it has stalled out
  7. Toyotaguy_7
    Aug 22, 2007
    951
    bump.... bump
  8. dailycruzr
    dailycruzr New Member
    May 14, 2008
    333
    lol i get it!!!!:biggrin: nice one!
  9. ntinhri
    Feb 1, 2007
    8,104
    whats the code?
    what happend after you unplugged the battery?
    have them have the battery checked..
  10. blastap
    blastap New Member
    May 20, 2007
    4,247
    the x1 needs to be fully seated into the harness. if its a o2 code then the x1 is not working or not seated
  11. ntinhri
    Feb 1, 2007
    8,104
    he has x-1? yup its the x-1!
    thewarriordinghy likes this.
  12. Toyotaguy_7
    Aug 22, 2007
    951
    well if the battery don't work then i''ll push on it when i get home for leave
  13. 5000XD
    5000XD New Member
    3,774
    I say it's the battery!
  14. x-driver21
    x-driver21 Member
    Nov 14, 2010
    310
    Was there a verdict on this? Just happened to me tonight!
  15. NHXRUNNER
    7,819
    235
    Ten year old thread bud......but if you have an X-1 make sure the ECU harness plugs are pushed all the way in, they were known rattling loose.
