Installing a Coupe Deep Oil Sump Pan
Discussion in 'How-To' started by Coupe, Sep 25, 2011.
  1. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    Kit comes with:
    1. Oil Pan with baffles & installed BMW trap doors.
    2. Tear drop oil pick up tube spacer.
    3. Stainless bolts, washers & lock washers for the tear drop spacer (long bolts)
    4. Two (2) Toyota gaskets for the oil pick up spacer.
    5. Stainless bolts, washers & lock washers for the oil pan. (short bolts)
    6. One tube of Toyota FIPG.
    7. Magnetic oil pan plug w/gasket.
    Drain engine oil.
    Jack up front of truck and install jack stands. Chock rear wheels.
    Take all of the bolts out of the stock oil pan.
    This is a pic of the stock oil pan, on the truck.
    I have a valve where the drain plug is. I do not recommend this. After closer examination, it will not allow the pan to drain fully. With all of the bolts out, gently pry off oil pan. Sometimes is you take a soft faced hammer and whack it, it will pop off.
    This is a pic with the stock oil pan removed. You can see the oil pick-up tube.
    Clean off oil gasket material off of engine block. Steel wool does a good job of this.
    There are two bolts that hold the oil pick up tube to the engine block. Remove these.
    I use a Q-tip and clean the oil out of the bolt holes. I am going to use loc-tite on these screws and I want it to get a good grip.
    The kit comes with a tear drop spacer. Place one gasket on each side of this spacer.
    The oil pick up tube goes on one side, the engine block on the other side. The kit comes with longer stainless bolts, washers & lock washers. I use a blue loctite (242) on the threads. Toyota says to torque the bolts to 80 in/lbs. I went a little higher to 100 in/lbs.
    Go put your oil pan bolts, washers & lock washers together and place conveniently to yourself under the truck.
    This is an important step. The Toyota FIPG is time sensitive. You need to install the pan in 15 minutes after coating the flange on the oil pan.
    Paint the flange of the oil pan with the Toyota FIPG. You just need a thin coat. DO NOT GOOP IT UP.
    I just used my finger to spread a thin coat over the flange.
    Wipe the engine block flange once more time, before installing pan. You will find that the oil constantly drips from the engine, during this install.
    Place the pan on the engine and put a few bolts in the pan and hand tighten. Put the rest of the bolts in the oil pan and hand tighten.
    I set my torque wrench at 50 in/lbs. Torque from the inside and work your way outward. See diagram. Follow 1, 2, 3, etc.
    Don't let the torque sequence overwhelm you. You want to start in the middle of the pan and criss cross to the ends.
    Then I set the wrench at 100 in /lbs (Toyota says 80 in/lbs). Do the same torque procedure. Do 1, 2, 3, etc.
    I let the pan set for a few hours to let the Toyota FIPG get a good bond.
    Put the drain plug in the pan and tighten.
    Replace oil filter.
    Fill pan with 7 quarts of oil. Start engine. Let run for a minute and turn off engine.
    Check oil. You may need to add ¼ ~ ½ quart depending on your oil filter size.
    Run for a few minutes and check for oil leaks.
    [​IMG][​IMG]
  2. xrgilly
    xrgilly Active Member
    May 1, 2010
    2,318
    Purddddyyy
  3. Xrunner Drifter
    Xrunner Drifter Active Member
    Oct 18, 2008
    1,138
    Wow, coupe that is a very well kit u put together.
    And an very easy how to. Good job and thank you for ur hard work.
  4. dramad1
    dramad1 Active Member
    Mar 27, 2010
    2,367
    Very nice write up full of pics. Once the engine is fixed I might hit you up for one of these.
  5. butters607
    butters607 Active Member
    Oct 3, 2009
    3,826
    Awesome man this is definetley a need for me!
  6. WallasX
    WallasX Active Member
    Mar 14, 2008
    1,140
    This is awesome i need to get one of these
  7. XR
    XR New Member
    Feb 17, 2010
    159
    Sweet man. I am ready what do I need to do to get one? Maybe you could pm me your phone number or something so I can get the info to send some money. Thanks
  8. sdxrunner619
    sdxrunner619 Active Member
    Jan 20, 2010
    3,835
    6
    Quick Q', why did you spread the silicone gasket materiel out? Toyota says to use a 3-4mm bead around the pan.
    I knew someone who used to spread it out like that, his cars always leaked oil...but what ever works for you :top:
  9. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    That would probably work also. One thing to bear in mind. The bottom of the engine is machined flat and is rigid. My oil pan is machined flat and is rigid. So these two surfaces are going to mate pretty well.
    If your bead is too thick, it's just going to squish all over the places. You will get overage into the pan as well as out of the pan.
    The stock oil pan is sheet metal. It may look flat, but I would call it kinda of flat. Also the sheet metal pan is somewhat flexible. As a result it may take a thicker bead to get it to seal.
    If I was going to do the single bead, I would do it down the center of the flange.
    I have not had any leaks so far.
    Excellent question.
  10. sdxrunner619
    Jan 20, 2010
    3,835
    6
    Does Your oil pan have the ridge that the OEM was has? your way will be fine for that kind of mating, if both surfaces are flat. OEM pan isn't flat along the mating surface. PITA, to get the old gasket off.
  11. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    I made it flat.
    I made the steel one flat also. No leaks on that one either.
  12. Workman3886
    Workman3886 New Member
    Jul 20, 2011
    1,358
    wow super clean, love the cooling fins, awesome job!
  13. KILAWATTS
    KILAWATTS New Member
    Oct 8, 2009
    31
    :crinklehair::canada::adore:
  14. burnboy
    burnboy New Member
    Nov 8, 2010
    860
    i bought coupes original pan. its on. letting the rtv cure for a bit and gonna fill her up
  15. Gxrun
    Gxrun Member
    Jan 9, 2008
    77
    nice write up:top:
  16. x8o8runner2012
    x8o8runner2012 New Member
    Apr 4, 2012
    251
    any prices on the oil pans, would love to install these on my truck
  17. xrgilly
    May 1, 2010
    2,318
    i think they are around a 1000$
  18. BBCorvette18Punk
    Oct 20, 2007
    410
    Any chance of these being available in the future?
  19. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    I have spacers with baffles in stock, but no oil pans. The spacers add about 1 quart.
    To make the oil pans, I need at least 3 people that want them and are willing to put up a deposit.
  20. BBCorvette18Punk
    Oct 20, 2007
    410
    Have a link to the spacers with baffles?
    Seems I took to long to get back into an X-Runner this forum used to be popping
