When mounting subs inverted in an enclosure do you have to reverse the polarity, or do you wire it the way it's suppose to be if it's mounted in the enclosure correctly? Thanks in advance!!!
Correct ! but if youre using two subs and mounting one inverted while mounting the other the regular way then youll have to reverse the polarity on one, usually the inverted speaker.
