just surpassed 170k....what now?
Discussion in 'Stock Performance/Mechanical' started by blu xr, Sep 29, 2017.
  1. blu xr
    blu xr Member
    Jan 13, 2011
    839
    like the title says...just rolled passed 170,000 miles on the xr. gonna look back to see when we bought it, but i believe there was around 30k when purchased. its an 05 and the only thing ive had to do other than reg maint. like oil & filters, tires, wipers, etc. was a throttle body cleaning that the oil change shop tricked my wife into getting lol.
    of coarse being in texas those are hwy miles, but it still runs strong and shifts good. i do have a few little issues i need to take care of, but nothing big i think. here they are...
    1. for a couple years i get a "clicking" noise when i turn my vent on for "inside" circulation. if i turn it back to "outside" and wait a few minutes, it usually goes away.
    2. the shifter is sloppy. it shifts fine and i rarely miss, and when i do, its prob my fault lol. ive own(ed) 3 supras, 2 of them being manuals, one was a 1993, the current project is a 1995 and have never seen this sloppy of a stick....actually none of the manuals on both 1993 rx7's i own now do it either.
    3. in the last couple weeks ive notice a squeaking sound at idle. when i depress the clutch, it goes away. if i let off...it starts squeaking again.
    any thoughts on the above problems?
    anyone else have these isssues?
    who else has passed the 150k mark?
    what good & bad have you seen?
    what can ii expect next?
  2. easts1d3
    easts1d3 Member
    Oct 17, 2011
    998
    22
    1. its probably your blower fan bearings
    2. you need to either do a coupe shortened shifter or buy a new shifter
    3.you need a new throwout bearing
    i have 180000 miles on my truck and i snapped a shifter fork in the transmission and blew up my ring and pinion gear and the Steering rack probably needs to be replaced.
    blu xr likes this.
  3. blu xr
    blu xr Member
    Jan 13, 2011
    839
    ^ thanks for the tips
    was your issues normal wear or are you pretty hard on it?
  4. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    850
    29
    Clicking noise is from the acuator Moter.
    Squeak is certainly the throw out bearing, it is annoying both of my trucks did that.
    If you have not had issues with you fuel system it is next. The filter in the tank always get stopped up.
    #4 autobodyX, Sep 30, 2017
    madtrucker and blu xr like this.
  5. Nashman
    Nashman Member
    Oct 22, 2015
    397
    20
    my front bumer creeks so annoying yet to lazy to tighten down the bolts on the front crash bars to the stubs that bolt to frame
    blu xr likes this.
  6. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,763
    13
    You may want to check the white plastic bushing at the bottom of the shifter arm before you replace the shifter itself.
    Remove the center console, push down on the ring around the shifter arm and turn it counterclockwise. You can pull the whole shifter arm out of the trans and that white bushing (or what’s left of it) should come out with it. But chances are the rubber bushing on the inside of the shifter arm itself is worn out also.
    blu xr likes this.
  7. blu xr
    blu xr Member
    Jan 13, 2011
    839
    bump for my first major repair...
    sitting a little over 187k and my alternator went out. took it to the dealer and they wanted over $600 to fix it lol.
    ended up doing it myself and saving $450.
  8. thewarriordinghy
    Apr 9, 2015
    578
    10
    167k miles here and ive done a water pump and I ripped a ujoint out and warped the driveshaft before...
  9. spicciani2
    spicciani2 Member
    Feb 22, 2018
    62
    10
    Sounds like yall are doing pretty well keeping the big items at bay at relatively high miles!
