Looking for an update: TRD SC with URD Pulley
Discussion in 'F/I Mods & Tuning' started by Nicodemus454, Jul 6, 2008.
  1. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    I figured a way around it would be to plumb the meth nozzle on the discharge side of the blower or direct port into the intake runners themselves.
    It appears that his blower has bearing problems.
  2. LSKustumz
    LSKustumz New Member
    Nov 6, 2007
    377
    That would be cool on the discharge side, after the intercooler though? Then you wouldn't have to worry about the meth getting into the bearings and burning them up or the seals and erroding them.
  3. 5H4D0WD347H
    Apr 24, 2007
    10,450
    Yeah right after the intercooler.
    I don't know how equal the dispersion would be into the cylinders though being so close to the ports (and not being direct inject).
    I suppose a two nozzle system on each side and smaller jets would be best.
    The most practical way is injection before the blower, just wish any possible effects of it were more definitive at this point.
    #43 5H4D0WD347H, Jul 9, 2008
  4. RedXr
    RedXr New Member
    Jan 4, 2008
    2,744
    so did this get away from the pulley topic?:biggrin:
  5. 5H4D0WD347H
    Apr 24, 2007
    10,450
    Nope! It's all relative!
    :biggrin:
  6. RedXr
    RedXr New Member
    Jan 4, 2008
    2,744
    LOL. well either way, i want to see this done. :top:
  7. Spyder327
    Spyder327 New Member
    7,098
    See what done, a methanol system running?
  8. WCD
    WCD New Member
    Jan 28, 2008
    910
    Already done! :rolleyez:
    Where did you plumb yours?
  9. Spyder327
    7,098
    lol which part, there's plenty of pieces :laugh:
  10. WCD
    WCD New Member
    Jan 28, 2008
    910
    So you plumbed in multiple spots?
    I wanna see!! :smile:
  11. Spyder327
    7,098
    You referring to where i placed the nozzle? It's between the MAF sensor and Throttle body on the TRD intake.
  12. Aspen_S/C
    Aspen_S/C Member
    Feb 28, 2008
    251
    I'm driving from Colorado to Washington state tomorrow to climb Mt. Rainier. I am purposely starting the drive at 9PM as going through Western CO and Utah is pretty toasty lately. Green river Utah will hit 103 tomorrow making IAT's of close to 120 in the day, not a good idea with the smaller pulley.
    I can knock 20 degrees off my Inlet Air Temps if I drive at night.
    I am interested in meth / H20 as well but want to see how it all goes for awhile...
  13. Spyder327
    7,098
    tell me about it :laugh:
    It gets to like 113 here during the day
    #53 Spyder327, Jul 10, 2008
  14. dak-rt-2a-XR
    dak-rt-2a-XR Banned
    Jul 8, 2008
    3,234
    Also washes the cylinder walls with gas removing oil resulting in less lubrication leading to the seizing of the pistons and blown rings..
    sound like fun ehh...
  15. Nicodemus454
    Nicodemus454 New Member
    Sep 18, 2007
    187
    So are you still running untuned with the meth and the pulley? do you still have your knocklight set up and have you had/noticed any pinging lately with the meth?
    So you're running the pulley without any tuning? have you noticed any pinging?
    my only concern with running that pulley is ever since i took off my maf calibrator, i think i might have a short in my wiring, cause every once in a while i will be driving and all of the sudden the fuel will cut out. and the truck will sit at a high idle. my foot will be to the floor (in neutral) and the truck will be sitting at like 1300 rpm. and the check engine light will go on. Ill shut the truck off, then turn it back on and its perfectly normal again, and the check engine light will stay on for like a day. I took it back to the dealer and all they did was replace the throttle position sensor. it ran well for a while then just did it again, randomly. i really dont want to go back into that wiring harness. that things a pain in the a$$
    has anyone else experienced this or something similar?
    How tough was the pulley install and what does it involve? i know it needs the special tool, but what else, and approximately how long?
    #55 Nicodemus454, Jul 30, 2008
  16. Spyder327
    7,098
    No knock at all when meth is active. Not positive on the accuracy of the light, but it only flashes if i disable the meth and go WOT
    Sounds to me like something in the harness shorting out like you said.
  17. ntinhri
    ntinhri Active Member
    Feb 1, 2007
    8,104
    currently I have a custom gadget tune.. how ever the dealer f'd up the mapecu so urd swapped it out under warrty.. I've been to lazy to put it back it. but I'm not driven the truck very much..
    also on the meth deal I emailed bob gardener at trd (lead guy)... he point blank said it would void my warrty and high suggested I say away... this is a guy who to this pointhas no problems with any of my other mods (he knows about them all) and has never said not to try something... not sure what it worth to u guys but I'm gonna say no to drugs..
  18. Nicodemus454
    Sep 18, 2007
    187
    So what is it exactly that needs to be done that you do with the map ecu2 ?? just correct the AFR to keep it from running too lean? did you need to retard the timing also?
    is that just on hot days? or pretty much all the time?
    #58 Nicodemus454, Jul 30, 2008
  19. Super Werty
    Super Werty Active Member
    Jul 12, 2007
    6,283
    It's Arizona, so probably 8 or 9 months out of the year:laugh:
  20. ntinhri
    Feb 1, 2007
    8,104
    to be honest gadget had the laptop, he told me to drive.... but i think he built in some timeing for safty.. Im sure he could tell you what he did..
