LS2 swap
Discussion in 'Member Builds' started by kwigs160966, Jun 29, 2015.
  1. Torspd
    51
    What sequence of events took place for ryanschmidt to be at this point.
    Doublld likes this.
  2. Doublld
    Doublld Active Member
    Jun 12, 2013
    1,089
    20
    hey man i got a solution for a/c if your interested
  3. iniazy
    iniazy Active Member
    Jan 29, 2014
    523
    35
    Oh man that looks good!
  4. LAzevedo
    LAzevedo Member
    Jan 13, 2009
    80
    6
    I'm looking to do an Ls2 swap (Engine and T56 m/t). Any help/suggestions??
  5. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    If you can find an ls3 rather than an ls2 it might be a better option. The ls2 was only made for a few years and the ls3 had a longer run giving it a few more options for adding things like an lsa supercharger. I also used a one piece aluminum driveshaft from a GMC Sierra, 05 I think, it's a cheap option for an aluminum one piece. And it is best to have it before you perform the swap. Probably the worst part of the whole swap is the rad support, I cut mine out and regretted it later. Try and decide what kind of accessory a you want to run before you start too.
    I would highly suggest to find a full engine with ecm and accessory/pulleys. A donor car is a great option but if you go that route don't toss anything out till your done, even bolts came in handy.
    From there it's just a matter of actually getting started and then a few of us are capable of providing lots of support.
    Good luck and I look forward to seeing the swap. I would highly recommend it.
    MrX-runner likes this.
  6. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    Yeah that would be COOL! Lol. What did you come up with? Mines been sleeping all winter and I'm itching to take her out for a rip
    darthyota likes this.
  7. Doublld
    Jun 12, 2013
    1,089
    20
    i had a guy make sub harness that controls the compressor and fans off a high/low pressure switch. no ecu needed. also got a block that goes on the compressor so i can make my own lines.
  8. LAzevedo
    LAzevedo Member
    Jan 13, 2009
    80
    6
    I've decided on sticking with the 1GR and doing the T56 swap. Transmission and swap kit should be in next week. How would I use a URD Stage 3 Clutch and 18lb flywheel with the T56?
  9. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    I th
    Pretty sure you would have to buy a new clutch setup from URD the fly wheel should work just fine but the input splines on the t56 are different than the 1gr transmission. If you haven't already got the transmission it would be worth looking for a GTO t56. It has triple cone syncros in first and second. Makes for a nice shift.
  10. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    What did you have in mind for connecting the lines to the stock firewall ports? I've seen some blocks for connecting to the ax compressor. Does the harness use the factory controls as head unit as well? Sounds interestig
  11. Doublld
    Jun 12, 2013
    1,089
    20
    no full standalone for a/c. the lines i can do two different ways. i was either gonna have my friend machine pieces to fit into the lines coming from the firewall or using the factory lines and cutting them and welding barbs onto the lines.
  12. LAzevedo
    LAzevedo Member
    Jan 13, 2009
    80
    6
    The transmission is already on its way. Brand new T56 Magnum with 2.66 1st gear. I read on a write-up here that I can use this :
    https://m.summitracing.com/parts/ctf-381017
    Don't really know if it'll work as I have no experience with swaps and such.
  13. Torspd
    51
    Double check to see if the Earl's Performance hard fuel line(aluminum fuel line) fittings, or Aeroquip fittings will work first. Just an idea. Those, if the tube sizes are the same, would then mount to the lines coming out of the firewall. Then you could use soft A/C hose, to route it wherever you want.
  14. Torspd
    51
  15. Doublld
    Jun 12, 2013
    1,089
    20
    ive looked into those before i may have to go this route if the cost of machining oring style fittings that go into the evaporator are too much
  16. Torspd
    51
    I imagine those parts will be cheaper.
  17. Doublld
    Jun 12, 2013
    1,089
    20
    there are weld on a/c fittings at www.coldhose.com ill be using these. i cut the lines that go into the evaporator an will weld them there. will still be quick disconnect
    Torspd likes this.
  18. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    I performed a little weight reduction on the x last week.
    -spare tire -58.8lbs
    -jack/wrenches -5.2lbs
    -rear floor mats and rear seat belts -7.2lbs
    -a/c compressor (ls2 not 1gr) -18lbs
    She weighed in at 3600lbs with 1/4 tank of gas so 3790 with me in it.
  19. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    Also did some bracket racing this weekend. I'm really starting to get the truck dialed in, I will upload some videos when I edit them a little.
    8.4 in the 1/8th mile. Should be good for around 13 flat in the quarter. The motor is stock and rated at 400hp
  20. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
