LSX swap, UCON-EMS or Megasquirt 3
Discussion in 'Member Builds' started by ssxv5, Nov 12, 2017.
  1. ssxv5
    ssxv5 New Member
    Jul 16, 2008
    6
    I'm doing a turbo LQ4 swap and I'm looking for some insight into what I should use for engine management. Can the UCON be real time tuned, can it run a LS engine. I know the MS3 will do everything I need as far as engine management but it won't interface with the stock ecu and I'd like to use the factory gauges and keep cruise control. Any information will be helpful. Also if you know of other ways of going about this that would be great. Thanks in advance!
  2. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    Make sure you get all the electronic components as well as the Ecu. I know a lot of guys run the mega squirt but I'm not entirely sure what the advantage is. You won't be able to use the ucon it's a good item to sell though. Do you allready have the motor? The ls based ecu's are as close to stand alone as you can get and the other components aren't too difficult to tie in. Also get the gas pedal from the same vehicle if you want electronic throttle.
    As far as factory gauges. You will need a Dakota digital speedo unit and you can make the tack and speed bang on. Most of the wiring isn't too hard to tie in. You'll see once you dig into it though. Fuel gauge is separate so no worry there it will still work I used an after market water temp sensor so my factory gauge doesn't work but it doesn't bother me. The only other thing is the CEL I never wired mine up either but it can be done I think. I never wired up the cruise because I broke the clock spring and havnt replaced it yet but it can also be done.
    Long story short. Use the factory lq4 ecu but make sure you get all components. Including gas pedal and tcu if running an automatic. You can probably sell the Tacoma ecu you won't need it. Also make sure when you put the motor in to it set it 1/2" to the passenger side so it lines up with the diff.
  3. ssxv5
    ssxv5 New Member
    Jul 16, 2008
    6
    Thanks for all the info! I was hoping you would comment on this. I read your thread following your swap and thought you did an awesome job. The engine looked right at home in the truck and the fit and finish look great.
    I have a whole donor '05 3500 express van. So I've got everything. I plan on running a t56 trans, I still want to row the gears. I'm not worried about having to wire up a gauge set or figuring a work around for cruise I was more hopeful the UCON would solve those things in a simple way. I've swapped LS motors before and built harnesses and programmed ecu's I'm good with that. My problem is I moved away from my buddy that has a dyno and all the tunning software so now I'm stuck with the tough decision. Buy HP tuners or go with another system. The MS3 gold box has a lot more safety features for boosted vehicles and handles boost control as well as it has a built in MAP sensor.
    What ECU did you use P59 or E38? I'm still unsure about messing with DBW. I'm concerned with a WOT run away situation after I mess with the program. I've only ever use DBC.
    Thanks, Eric
  4. kwigs160966
    kwigs160966 Member
    Oct 5, 2011
    631
    My ecu is an e40 it's not the most common because it is from an 05 ls2. I use hp tuners, it wasn't cheap but seems to be all I need. I'm not sure that you would have any issues with DBW runaway as long as you use the factory wiring.
  5. Blue10XR
    Blue10XR Member
    Dec 13, 2014
    342
    21
    If you don't use the factory ecu for DBW then you will lose cruise control and VSC.
    kwigs160966 likes this.
