SignUp Now!The engine? or the car? The engine is tiny. I can see the floor from in front, and behind the engine.Omfg... that thing is so tiny.... :hahaha:
Yea. I had talked to Power Enterprise the day after the install, and already made those corrections. Those pictures were taken the day of the install. I guess the charger was shipped to me with the housing mounted off by a bolt. I'll put some updated, with pulley pictures up pretty soon.Nice setup.
I do see one thing that needs to be corrected right away or the supercharger will likely fail very soon.
There are two oil pumps in the unit. A pressure pump that supplies the oil to the internal workings of the supercharger. The other is a scavange pump that removes the oil from the unit and pumps it out to the oil cooler and back to the defoaming tank.
This is like a dry sump system found in engines. For the scavange pump to work correctly the recovery sump must be properly positioned.
There is a flat side of the supercharger. That must be installed facing downward so the oil will collect in the sump for the scavange pump.
I can see that it is not properly mounted due to the position of the oil line fittings. This is simple to correct. Just demount the unit and rotate it to the proper clock position and remount it to the bracket. You will likely have to reclock the snail. This is done by removing the three very small allen headed cap screws from the front and rotate the snail to the proper position and reinstall the the three cap screws and remount the unit to the bracket.
Here is a link to the data sheet for that supercharger model:
http://www.rotrex.com/pdfs/Rotrex_Technical_Datasheet_C15_Range_V4.0
Naw, I know. Even with the ribbing, I haven't even posted this much information on the Yaris forums.ddong, I know the guys rib you a lot and you take it like a champ --- but in all sincerity, damn I'm sad we lost you as an XR owner.
