- Jan 13, 2007
- 10,932
- 173
Did you disconnect any fuel lines for any reason?
If so, they are those "quick disconnect" types and have O-rings inside of the plastic connectors.
You should always lube the part you are sticking into the connector, the male part, so that it will slide into the O-ring without screwing it up.
Then there is a plastic safety clip that goes over the whole connection as a secondary thing to keep the fuel line from pulling off of the male part.
Lets hope it is something real simple like the return line just is not snapped all the way onto the fuel pressure regulator.
