New exhaust set up...hopefully my last
Discussion in 'F/I Mods & Tuning' started by Super Werty, Jan 3, 2010.
  1. Super Werty
    Super Werty Active Member
    Jul 12, 2007
    6,283
    It's been a very long journey with exhausts on this truck, and hopefully this will be the final and best sounding/best performing set up.
    My set up a few weeks ago was:
    -DT long tubes
    -URD 4x4 Y
    -URD 3" with dynomax (aka quiet muffler)
    This set up sounded great once warmed up. I was very satisfied with it. Except I decided to cut off the tail section one day because I wanted it to be more stealth. However in doing that ,the sound resonated under the bed and made it much louder inside and out...which I actually was ok with, but I was worried I might get pulled over for its loudness.
    where I cut it...
    So I took Gadgets advice and bought a second straight through magnaflow....only instead of a 18" I bought a 14" hoping it would be more quiet but not as quiet as his truck. Well it turns out this muffler combined with the dynomax shut it up almost 100%. It sounds like stock but with a weird deep drone to it. I tried to convince myself to like it but I just cant take it anymore...I want it to actually sound like it has some power under the hood. The other problem was the muffler was welded in tilted/crooked to avoid hitting the cross member...the 3" exhuast is why it's so close.
    crooked shot and look how close to the cross member it is...
    So I listened to many different set ups I decided ntinhri's sounded the best, but I still wanted to experiment a little, so I'm going to try this...
    Im going to keep a 14" second muffler(center/center), but I will swap the 5x8x14 for a 4x9x14....this gives me the same amount of muffling material, but in a shape that will fit under the cross member...so it wont be welded crooked like it is now. It should be straight.:top:
    Then I will remove the dynomax for this beast of a straight through(center/offset). It's a 22" long magnaflow 5x11. Which is actually a 6x11.5x22
    Im hoping it sounds good...I wont know until monday or tuesday when it gets welded in. I will post a video when its ready.
  2. zrgray
    zrgray New Member
    Mar 8, 2009
    237
    Blah... Who needs quiet? I'm about ready to upgrade to the URD y pipe to finish my exhaust. Hope it work for ya!
  3. T0LLPHR33
    T0LLPHR33 "Catwoman"
    Jun 17, 2008
    10,969
    that setup looks really good will...can't wait to see and hear the end results...:top:
    a dump setup like yours is exactly what I plan to do with my truck...:biggrin:
  4. THE MACF
    THE MACF Active Member
    Mar 12, 2008
    1,651
    Whats the difference between the 2wd and 4wd y-pipe?
  5. Super Werty
    Jul 12, 2007
    6,283
  6. THE MACF
    Mar 12, 2008
    1,651
    no kidding. thanks.
  7. Mano
    Mano New Member
    May 17, 2009
    237
    Thats the same large muffler that im running as my main muffler .. but i have it coupled to a 5x8x14 and a 5x8x18 .. its kinda quiet but above 3000 rpm its still got tone ..:top:
  8. Super Werty
    Jul 12, 2007
    6,283
    In a 3" pipe? And I still can't believe you did 3 mufflers...thats gotta be so quiet
  9. Mano
    Mano New Member
    May 17, 2009
    237
    Yup its 3in pipe .. and it is quiet until it get above 3000 rpm WOT .. then its :biggrin: .. but thats what i wanted a really quiet exhaust that was straight through .. but there's still vibrations that are kinda annoying .. i think its coming from my exhaust but i really don't no ..
  10. trdguykc
    trdguykc New Member
    Dec 29, 2007
    219
    subscribed yet again, cant wait to hear it!
  11. Super Werty
    Jul 12, 2007
    6,283
    Ok I just got back from my exhaust shop and I think iI just found the perfect set up:rock:
    It sounds WAY different than before. From idle to redline, its completely changed. No rasp. A small amount of drone in high gear low rpm
    It has a low deep rumble at idle, nice tone while cruising and the best part...at WOT it doesnt even sound like a 1GR anymore. It has this exotic sound to it. Im not joking...it's perfect.
    I will try and get a video clip today if not sometime this week.
    #11 Super Werty, Jan 4, 2010
  12. blastap
    blastap New Member
    May 20, 2007
    4,247
    whats the difference in the dynomax(quiet) and the big magnaflow?
  13. shaggy08xr
    shaggy08xr Active Member
    Sep 25, 2009
    2,239
    I'm with ya bro I like the idea of a sleeper but I like a good throaty exhaust note. Ur setup looks awesome and can't wait to hear it, so when are we going to get a sound clip
  14. Super Werty
    Jul 12, 2007
    6,283
    the best way to show you is with pictures...
    the dyno max super turbo is shaped like an S inside.
    http://www.dynomax.com/mufflers.php?muffler=superturbo
    Where as the Magnaflow is straight through design... see pics on page one
    Should have video tomorrow. Hopefully my camera will be able to pick up the sound.:top:
  15. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,903
    42
    I hope so too! :top:
  16. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,903
    42
    Bump for video clip!
  17. KETCHUP
    KETCHUP Active Member
    Nov 1, 2007
    11,665
    looks good brotha. hopefully what you wanted finally.
    wanna hear that video. I may take that other mag off ur hands
  18. Super Werty
    Jul 12, 2007
    6,283
    Ran out of time today. Hopefully I will be able to do it tomorrow:top:
    I got the magnaflow waiting for you Ketchup:biggrin:
  19. KETCHUP
    Nov 1, 2007
    11,665
    cool brotha! wonder how it will sound on mine? I think I have close to the same, but it was used and the guy welded hangers on the outside of the muff which is a NO NO with a mag.
  20. R1 Chris
    R1 Chris Member
    Aug 8, 2008
    842
    do that i would love to hear it.
