Offset and square stance
thechief21040
I was wondering what offset I would want to use if I want me tires to stick just past the wheel well.
Also I wanted to go with a 20 x 10 wheel and was wondering if anyone had a square stance set up on there X???
NHXRUNNER
"New Hampster"
Your best bet to get it where you want it is to measure it yourself and then do the math. :top:
NHXRUNNER
"New Hampster"
Just keep in mind, offset is a function of width. You change the width and the offset changes with it. Basically the lip of the wheel at +15 on a 9" wide wheel will not be in the same location on a 10" wheel.
thechief21040
I saw somewhere on here someone had 305's all around anyone no where to find that picture? I think I'm gonna go with a tsw Nuremberg 20" X 10" with nitto 295's all around anyone rocking a similar set up? I couldn't find anything like it in the wheels and tires thread
BSP06XRU
Old Member
Try this thread:
http://www.xr-underground.com/forum/showthread.php?t=36832
and while you're there, check out Snoopy's setup:
http://www.xr-underground.com/forum/showpost.php?p=745771&postcount=20
thechief21040
That's exactly the picture I was looking for thanks yeah snoopy' set up is what I am kind of going for just 295's in all 4 corners, thanks a lot
