Super Werty
- Jul 12, 2007
- 6,283
- 4
not bad considering it's not a full on stage 3 yet! very nice!
SignUp Now!I don't get how they can't display tq. I believe the HP is all figured off of the TQ numbers....
Typically when the tach pickup is off though it also produces HP numbers that are way off.
The 5252 formula for HP calculation still applies here.
well this run i posted is with it on so i beg to differ on it being off at all cause i personally saw the graph come up for this run bro but it was chopped in half from the signal bounce hate to burst your buble but all the runs were consistent with it on and off batman!
Did I not tell you that he would pop in from out of the blue and be trying to discredit your dyno result?? Didn't I tell you that??
No where is that other guy??
On a DynoJet HP is calculated by how fast you can accelerate the drum. Known mass acceleration rate.
They need an RPM signal to calculate torque off of. DynoJet normally uses an inductive pickup to get the RPM signal from the power wire going to one of the spark coils. Those can be problematic and loose signal a good bit. Many times the torque line will have gaps because of that.
399.6 RWHP for a Mk3 Stage 2 on a very hot day with El Paso elevation is very respectable indeed, but damn, so close to the big 400....
hey if i was a mustang owner i would hate hate hate too :motz:
Hey either way we can figure out your TQ curve for you based on the HP curve via the formula, its very easy to do so.
We just need to know approximately what RPM you started your pull at (which we can probably estimate based on MPH).
Here on our dyno (FP Mustang & an older dynojet 248x) if you dont get the tach pickup correct the HP curve is not correct.
I had this problem with my truck when I was setting it up as well, I ended up grabbing it at the coil itself.
typically I use a loop wire, I was trying to use a gator on the XR and it wasn't working well.
U guys are too funny, as long as this doesn't turn into what either Rexrunners or Megabitz's dyno thread turned into. At least Butters isn't claiming over 500ftlbs of torque lolz!!
Nice numbers BTW, now hurry up and get ur stage III gear installed so we can see u at least beat BlackX's #'s and maybe even Gadgets.
And get the dyno file so u can shut Doug up and before XrunnIT gets on here and starts his shit!
No one is discrediting lol, I believe there is a lot of congratulating going on if anything.
hahahaha! ooooo now youve done it!
Had to bring the mustang thing into it rofl.
Will gladly race .
will gladly accept after i get to stage 3 thanks!
Im down!
I think it would be a great race actually.
Stock N/A 5 liter vs. Boosted 4 liter
American Car vs. Jap truck
Rustang vs. Taco
ok i dont know jack about the dyno machines but if its so off how could it be so consistent 4 times please tell me?
