oh yeah moment of truth
Discussion in 'F/I Mods & Tuning' started by butters607, Jun 24, 2011.
  1. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    Dynos are worthless when it comes to peak numbers there is way to much of a range on them; its pointless arguing over them or comparing them.
    All that matters is the area under the curve.... Don't pay attention to peak numbers, pay attention to the powerband and how much OVERALL power you are gaining/making.
    Use dynos as a tuning tool and a baseline/mod gain evaluator.
    You want to know true RWHP?
    Trap speed and vehicle weight = WHP.
    Even 40-90 can be used to determine WHP.
    The time it takes to accelerate a known mass from A to B is flawless, unbiased, and universal anywhere in the world.
    Again nice numbers butters.
  2. butters607
    butters607 Active Member
    Oct 3, 2009
    3,826
    I'm pretty sure that the plx device measures this I have seen their app don't know if it works or not but
  3. blackx-runner
    blackx-runner "White Flash"
    7,581
    13
    What mods did you have? I doubt you were quite that high being NA, but its always possible.
    I would guess the URD added closer to 130-150 RWHP. :blurock:
    That's just a guess from other dyno numbers and the fact that I dynoed the same day as a URD MKI stage I truck with DTLT and full URD exhaust and I had over 100HP on him.
  4. Murderface
    Murderface New Member
    Feb 27, 2008
    11,937
    Damn David u made over 100hp mode then a MKI? What stage were u and u said he was stage I MKI right?
    Also I highly doubt u Butters that u had 300rwhp with all ur mods NA. I know Chrisjaxfla made close to 300rwtq but the rwhp was much lower. So it's possible that u had close to that 300rwtq but no way u had close to 300rwhp. Too bad u didn't get a NA dyno and a F/I dyno within a close time frame at the same dyno with close temps between the runs. That I would like to see.
  5. blackx-runner
    7,581
    13
    I was stage III (70mm pulley) and yes he was stage I (85mm pulley) . You also have to remember I am running the -71 trim blower, not the -81 that butters is running. He's getting some serious power from that supercharger isn't any doubt about that. :blurock:
  6. butters607
    Oct 3, 2009
    3,826
    Afe stage 2 si,x-1 Doug thorrley long tubes URD y pipe afe 3in exhaust, ikh20 plugs,nst intake manifold spacer so yea I'm pretty sure I was between 290 and 300 you guys can add up the totals from these parts just the x-1 is 30 hp to the wheels and 20 ft lbs lbs torque isn't it?
    #106 butters607, Jun 26, 2011
  7. blackx-runner
    7,581
    13
    That's the things with mods. Its not just simple adding them all up. That's where a before and after dyno can really tell you what gains each mod is giving you.
    Like ChristDenied I was comparing your truck to Jaxchrisfla who did a dyno with similar mods. In his case the addition of the X-1 to his other mods only netted him 12hp, but 32ft lbs tq. He was at 255HP and 298 TQ with all his mods. I'm sure there are other NA dynos out there, but I don't recall any being significantly higher than his. I would guess you were in the same ballpark as well. 250-270 RWHP and around 300 RWTQ. But like I said its all a guessing game to which the answer will probably never be known. Unless you decide to go back to NA and do another dyno, but I really don't see that happening.
  8. rexrunner
    rexrunner Active Member
    I say 260 270 max.
    Trucks dyno 200 around stock
  9. blackx-runner
    7,581
    13
    Time to get yours back on the dyno now that you got that LS swap all done. See what kind of lines you get out of that V8. :blurock:
  10. butters607
    Oct 3, 2009
    3,826
  11. rich017
    rich017 Active Member
    Aug 23, 2007
    6,328
  12. Murderface
    Feb 27, 2008
    11,937
    ^^^^What's he wrong about? he said around 200 stock rwhp and that sounds right. Just because G ran 209rwhp doesn't mean u will, another member got 207rwhp. I think the highest NA with no mods I saw was around 211rwhp.
    Rich u beat me to it, my post was intended for Butters
    #112 Murderface, Jun 26, 2011
  13. blackx-runner
    7,581
    13
    LOL did you read the thread you just quoted, or any other dyno thread for that matter.
    The first reply
    That's why comparing dyno numbers between different trucks on different dynos is absolutely useless. There are too many variable and too many factors to make an apples to apples comparison.
  14. rich017
    Aug 23, 2007
    6,328
    No, Justin said that a stock X will dyno around 200 and butter's he said he's wrong...
    A stock truck dyno's around 200-210whp
  15. butters607
    Oct 3, 2009
    3,826
    Ok its over 200 and i read it 207,209 sorry I must be crazy but that'd around closer to 210 idc doesn't matter still nobody added this up with ea part individually?
    And you can go to another thread cause I really don't care for you at all
    #115 butters607, Jun 26, 2011
  16. Murderface
    Feb 27, 2008
    11,937
    ^^^^^this:laugh::arsespank::punch::smack::aetsch:
  17. blackx-runner
    7,581
    13
    Adding up each mod individually is the ricer way to claim more HP. Its a fact that real life gains won't equal the gains of each individual part added up. Some may be more, some may be less. That's why before and after pulls on the same dyno can be so useful to see the "real" gains you get.
    Either way its a discussion that will have no answer. So lets just end this pissin match before the thread gets too crazy. :starwars:
  18. butters607
    Oct 3, 2009
    3,826
    I just figured it out guy had full mods just like mine 250-260hp there we go on a dyno my bad thought if you added them up it would work thats definetley not how it works! I just install the crap. and I was serious when I said rich can get out of my thread
  19. 1GRracer
    1GRracer "Pete"
    Aug 8, 2010
    3,586
    :deadhorse:
  20. Venomous_X
    Venomous_X Active Member
    May 11, 2008
    13,694
    lol, read a couple of threads, and all the sudden people are ****ing 25 year experienced mechanics... :bird:
