PCV System & Oil Catch Can
Discussion in 'F/I Mods & Tuning' started by Super Werty, Jan 13, 2010.
  1. stockredx
    stockredx New Member
    Jul 4, 2009
    91
    Now I know why the inside of my TB is all brown...:(
  2. Torspd
    51
    Amazing isn't it??? And to think this is common knowledge in race communities, yet the general public is left out of the loop. Then question it's effectiveness when brought up the advantages.
    I might get my mom one for her new car. Just to help keep things extra clean, longer:top:
  3. c0astie31
    c0astie31 New Member
    Jun 27, 2009
    144
    i did a oil change saturday, and i had a little under a cup of oil drained, i am happy with my install
  4. zr2ee
    zr2ee New Member
    Jul 14, 2009
    225
    hmmm so my dumb ass just learned about catch can's and now understands why my intake and MAF kept getting all sorts of greased up and my engine bay is always dirty.......
    so just to be clear even though i just read through the thread, best placement for a catch can on a turbo setup is the passanger side and a check valve is still required to keep the boost pressure from entering the crank case since its above atmosphere before the intake manifold, and you just cap off the drivers side or you put a breather on it?
    seems a breather on the drivers might help eliviate any boost that slips past the check valve on the passenger side....not sure how it would satisfy the MAF though
  5. Torspd
    51
    Lol. Sometimes it takes us a while to find these threads. Where you want to put the catch can is on the driver side as well. In line between the driver valve cover and the intake manifold. So...out of the driver side valve cover, into the catch can, out of the catch can, into the manifold with check valve only allowing air to flow into the manifold somewhere in that line.
    I can post a pic in up later tonight.
  6. 5000XD
    5000XD New Member
    3,774
    I have an idea how this should be, but please do post a picture for people as stupid as I :top:
  7. zr2ee
    zr2ee New Member
    Jul 14, 2009
    225
    that would be awesome thanks mark, my truck goes into the shop monday for the front mount conversion so i want to talk to him and have him put some in, we already talked about replacing the PCV valve. definately don't want my stuff being gummed up by oil but i think my biggest concern is a secondary relief if the check valve fails
  8. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    15
    I put one on in December, when I added a blower. I had about a half cup of oil in mine at the next oil change.
  9. Torspd
    51
    Once I get my truck back form the shop, I take some pics and post them up
  10. Torspd
    51
    Here you can see the "fresh air" filter on the driver side which would normally have a hose connected to the intake. Since my intake "pushes" air before the TB, I would have to have the previously mentioned hose connected to before the turbo. Didn't feel like running a hose that far. The vacuum from the motor will pull air through the filter just fine.
    Follow the blue hoses and you can see how they go. You can also see the check valve so that I do boost air into the crank case. It is between the intake manifold and the catch can.
    #190 Torspd, May 5, 2010
  11. Super Werty
    Super Werty Active Member
    Jul 12, 2007
    6,283
    ^ is that the new nst product I see? hard to tell from that angle
  12. Gadget
    10,899
    148
    It must be. Look at the plenum support bracket that does not line up any more. It seems that the plenum is sitting just a little higher than normal.
  13. Torspd
    51
    I don't see any thing...
    Gadget, I need to call you tomorrow about that package that needs to ship also. Still waiting and ready.
  14. Super Werty
    Jul 12, 2007
    6,283
    ah yes, I didnt see that at first. Looks like we just got a sneak peek:laugh::rock:
  15. zr2ee
    zr2ee New Member
    Jul 14, 2009
    225
    where is that line right after the MAF sensor going to? the one that normally goes to the passenger valve cover where that breather is
  16. Torspd
    51
    That is going to my boost controller soleniod. It is not a good idea to run that line to the passenger valve cover at all. Otherwise you run the risk of being able to pressurize the crank case. The PCV setup that STS sent to fit there should be removed. If it fails then you will pressurize
  17. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    15
    I had to pull the blower off recently, to put on new valve covers. This is a pic of my intercooler after 4K miles and using a catch can.
  18. blastap
    blastap New Member
    May 20, 2007
    4,247
    no complaints there James
  19. Super Werty
    Jul 12, 2007
    6,283
    So Coupe....
    When are you going to design a IC that sits under the blower like the stang's:biggrin::rockon:
  20. joelkustoms
    joelkustoms New Member
    Jan 17, 2012
    6
    correct me if Im wrong, the catch can should be installed on the driver side valve cover and intake bung because the other side is just clean air that enters the valve cover. I have one question, the catch can has o be pressurized (closed) or it can have a filter on top?
