SignUp Now!Im curious to know how hot the air is though at 16 psi. It's gotta be insane.
Im much more interested in doing the port. I wish he had just done that first.
meth is for squares
Snakebite? Saw a post on CT asking but no answer. Be nice to see a before pics for a good look at the difference.
Think of it like this, restriction causes friction. That friction then causes heat. So, reduce the friction, reduce the heat. How much so, I have no idea. It might be enough to where heat at 16 psi on the ported setup is equivalent to the heat on a non ported 12 psi setup.
Efficiency always works wonders.:top:
If you say so but it's relitively cheap and available compared to nitrous like up here in the great White north they sell it at the gas station:laugh::laugh:
does he know if the 16psi blew the foam out??? i didnt read all of it....
To my understanding they also have some sort of OD gear set up for the snout. I think the gears is where the 16pis came from the port was "only done where they could reach". SO while it was ported, I dont think the entire track was ported. I think any of us with a dremel could port out the s/c, we just wouldnt have the gears set up.
I know you can buy e85 here but not at the gas station so blue window juice up here is they way most go up here and yes nos is readily available just as much so as blue window juice but you don't have run meth just for anti knock some use it as poor mans nitrous
Can you do nos and gas through the 7th
Should have had them make a little larger intercooler while they were in there...
i think you would have to have two injectors.. ?? ... :dontknow: plus nossssss is at a higher pressure than your fuel system.. sooo i think in that case if you were to do that the nosssssss would over power the fuel and it would only spray nos and no gas... same if it were tapped into the fuel rail...... motor may sound like it has popcorn in it :laugh:
otherwise i think everyone would just tap into the fuel rail and spray away:dontknow::dontknow:
i could be way wrong..... but that is what i think...... :dontknow::dontknow:
Nosssssssssssssssssssssss!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
