Re-Installing My Supercharger
Discussion in 'F/I Mods & Tuning' started by iniazy, Aug 18, 2014.
  1. Torspd
    40
    Yup. I am with Gadget. When is the last time you checked, or cleaned your air filter?
    I had a really clogged one once, when mine was rear mounted. Was a pig off of the line and through acceleration. Wouldn't even hit boost, and I had a 8 psi spring in there. Pulled the air filter snorkel off of the turbo and bam! Truck ran like a champ!
    The filter was horribly clogged.
  2. iniazy
    iniazy Active Member
    Jan 29, 2014
    521
    33
    I guess I need to check my air filter, it's been a while since I last cleaned it.
    There's bad news. I cracked a piston finally. Last night when I took the car for a wot run it knocked bad because the low boost took the fuel map to places not previously tuned properly making it a little lean, and since I drove back the engine never came back to normal. It's blowing out oil vapor like crazy, and lost lots of power. A round trip to work blew out almost a half a quart. I work 60 miles away.
    Time to rebuild my old engine.
  3. Gadget
    10,830
    102
    Maybe your problem was with your MAP sensor.
  4. iniazy
    Jan 29, 2014
    521
    33
    I have a boost gauge along with the map sensor, and the two are consistent in their reading, and my but dyno concurs. So I think map sensor is fine.
  5. Torspd
    40
    Have you checked the air filter yet?
  6. iniazy
    Jan 29, 2014
    521
    33
    Not yet. Filter needs a few hours to clean up so I'm waiting for my Miata to come out of service so I can have another car.
  7. iniazy
    Jan 29, 2014
    521
    33
    I checked the air filter, it was dirty. Really dirty. I cleaned it up properly and oiled it, and checked with my mouth to see the difference in flow, and it made a big difference.
    After cleaning it I also removed that ugly 3" joint box that came from Alpine, which was probably adding a lot of air flow restriction, and just connected everything through normal 3" silicone couplers, and now I feel the engine really powerful, even while running with only five good pistons! I wish I did that before I cracked the piston. The car feels so strong I can hardly believe there's a cracked piston, if it weren't for the jerkiness when I stop while on Drive in a traffic light, or if it weren't for all the oil that's being consumed/blown out of the crank case breather.
  8. Torspd
    40
    Crazy what a little "restriction" will do huh? ;)
  9. Torspd
    40
    @iniazy , which 1GR vehicles over there have the 5 speed transmission?
  10. iniazy
    Jan 29, 2014
    521
    33
    1. Fortuner 2006-2015 Single VVT
    2. Land cruiser LC200 2008-2011 single VVT and 2012-present dual VVT
    3. Land cruiser 70 series 2010-present single VVT
    Torspd likes this.
  11. Torspd
    40
    Awesome! Thanks!
  12. NHXRUNNER
    7,516
    127
    a
    Are you thinking what I'm thinking? 5spd swap from overseas?
  13. Torspd
    40
    Not for me, but thought about it for years. Brought it up many a time. Got another thread going where the topic is being discussed.
    Subsequently though, yes. The R154 is a beast of a trans. The R155, I am not so sure of. I am curious what the bolt patter of each of those transmissions looks like sided by side. Without the bellhousings attached.
  14. Torspd
    40
  15. iniazy
    Jan 29, 2014
    521
    33
    I think they should have identical bolt patterns. I think the differences are in gear ratios only.
  16. Torspd
    40
    You wouldn't happen to have any pictures of the 5 speed transmission without the bellhousing attached, would you?
  17. iniazy
    Jan 29, 2014
    521
    33
    I'll try to find something.
    One thing I know, the 70 series Land cruiser five speed is probably very different than the one in a fortuner and LC200. The 70 series have completely different ratio gears, geared for heavy towing rather than smooth driving. Also, I saw the bell housing and it seems very long, seems much longer than the one in the fortuner. The transfer case also is different, it is old school gear driven, rather than chain driven as in the fortuner and LC200, with a different shifting pattern and really hard to engage compared to the chain driven one.
  18. Torspd
    40
    Hmm. Let's stick the the Fortruner one then. Seems closest.
  19. iniazy
    Jan 29, 2014
    521
    33
    I'm so frustrated with my supercharger. I'm continuing to lose boost by the day, now I'm NA-close 3 PSI only! I thought it was the belt, so I just replaced that with a one that fits very tight, but it's still really down in boost. What's going on?
    Only possible thing is my rotrex supercharger is losing efficiency. But no one ever had that happen to them, according to my research. The rotrex always just breaks, never seen any one reporting loss of efficiency.
    I want to buy a replacement, but I'm worried it would turn out from something else, and $2500 is not pocket change.
    Any suggestions?
  20. NHXRUNNER
    7,516
    127
    Send it to Stiegemeier for a rebuild. Should be way cheaper than an entirely new unit.
