SignUp Now!Maybe your ecu is programmed in PAL, whereas the UCON is in NTSC..... Needs to be unlocked. :crinklehair:
What if you switch your ecu with another to cross check? Worth a shot since you know the ucon works on another vehicle.
It shows how resilient those Toyota trucks are. I've had a check engine light coming on every now and then for several years, code P0606, and the diags say to replace either the ECU or the harness. I've always ignored it because the truck ran normally.
