RedLantern's turbo build....
Discussion in 'Member Builds' started by Redlantern, Apr 24, 2013.
  1. TRON
    TRON Member
    Oct 12, 2009
    472
    Well.... One of the biggest problems is my AFR numbers running consistently at say 65 mph. My afrs will clock back and forth 15.2 straight to 14.2 then back to 15.2 then 14.2 and so on at a consistent basis. The signals the front wraf and back hego sensors communicating are providing incorrect data to the EMS for some reason. Which is weird cause i have 4 brand new sensors in. Vbands with step lips headers back. The correct data should be targeting the Ucon EMS to an AFR close to 15.2 at a steady 65 mph. Ive talked with Scott a few times and sent him data logs etc about it... I'm just getting tired of dealing with it...Work is crazy right now. Got to pick your battles but luckily my reflash runs fine as long as I don't WOT.
  2. STONER-X
    STONER-X Active Member
    May 15, 2008
    3,372
    I had an AFR issue like what you mentioned.. my issue was I needed an air flow straightener..
    the air was picking up some turbulence somewhere and it would cause the afr to jump all over the place while going down the freeway.. after I got a straightener it was a lot more "normal" also the position of my MAF had a roll in my fuel trims.. it had to be in a "factory" up style position or my fuel trims would be way out..
  3. XMPLRY808
    XMPLRY808 Active Member
    Dec 5, 2014
    399
    73
    Hmm... I too have this problem. But when I a cruise on the freeway above 2k rpm in 6th gear my afr stays at a steady 14.6. Since I have a dual wide band set up one on each bank my bank 2 acts wild sometimes but my fuel trim seems to be good. I checked for exhaust leaks and it was all good. So I just tune my truck using the afr from bank 1
  4. fishsticks
    fishsticks Because fast lifted truck.
    Nov 29, 2015
    207
    6
    Mine sweeps as well until I get into the throttle. I was always under the impression that this was normal closed loop operation.
  5. Gadget
    10,871
    126
    Yes, the 1GR ECU does not hold a steady 14.7:1 AFR. It will run richer, then leaner, then richer, then leaner and so on. If you connect a scan tool and monitor the commanded AFR you will see this constantly changing. It does not do that on my 3.5L Tacoma. It is very steady.
    One theory for this is to enhance catalytic convert efficiency.
  6. XMPLRY808
    Dec 5, 2014
    399
    73
    Was thinking to try retune and try make it more "perfect" but good to know that it's normal lol thanks gadget!
  7. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    My afr fluctuates as well. U had me thinking for a bit but when I looked at my old videos, it's been doing that from the beginning I had my wideband installed. As stoner stated, a flow straightener may be a good idea. I need to get me one as well since it reads more turbulence than the URD sc sees.
  8. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    Small update. Been working so much that I forgot I ordered a flow Straightener from treadstone performance. Came in the mail today and had some time to at least install this before the maf. Reason for buying this is due to higher turbulence reading in the maf from my turbo compared to urd charger. Should definitely help.
  9. XMPLRY808
    Dec 5, 2014
    399
    73
    I wonder how much difference it'll make... Just don't install it the wrong way :laugh:
  10. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    Lol. Its the right way. Install was pretty easy. Just had to fold the edges a bit for it to fit into the 3' maf housing. once it was partially in, i put epoxy on the sides then flipped it to where the honeycomb was on the table and the maf housing was on top and slowly pushed down so it slides in nicely.
  11. Torspd
    47
    That turned out great. Get a datalog and compare. :top:
  12. STONER-X
    May 15, 2008
    3,372
    They make a large difference there are tons of videos one the tube of the you
    https://youtu.be/KNExOgtLt2w
  13. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    I will as soon as I get the ucon back into the truck. Have to swap injectors again.
  14. Torspd
    47
    Gotcha. Well have you noticed an improvement in drive ability since the install? That alone would be proof.
  15. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    When I drove it to work today, I was watching my AFR. It's a lot more stable. Used to fluctuate from 14.3-15.7. Now it stays between 14.3-14.7. Only time it goes to 15 is when it shifts.
  16. Torspd
    47
    Proof in the pudding. :top:
  17. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    Finally installed my suspension. Looking to get some light racing UCA since my caster and camber is a bit off. Hopefully that will help with the alignment. Other than that it drives straight.
    Before
    After
    I'll try to get better pics. Been raining a lot this week.
    TitanRattler813 likes this.
  18. Torspd
    47
    Hot damn!!!!
  19. XMPLRY808
    Dec 5, 2014
    399
    73
    Looks great but get boostin already!
  20. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    Working on it bro lol
