05H0TWHEELS
- Oct 22, 2008
- 908
i just got mine:biggrin:
SignUp Now!you can change how fast you want the scangauge to read the OBDII port...should be in the options menu some where...
if you can't find it I'll take a look at my SGII on my lunch break...
Extensions and heat sinks should work; after all that's why Innovate made them. :top:I'm impressed, this works pretty damn good for what I need, glad I found this!
I am about to give up on my expensive and mostly useless Innovate system, I am pretty sure it has to do with the bung position in the stock header being so close to the actual exhaust, blazing hot.
It only works when it is cooler out, as soon as it hits 60 degrees or higher, forget it, the thing reads -.-.- all the time.
Anyone have an idea what I can do to cool down the wideband sensor? I am wondering if an 6-8 inch extension with a series of heat sinks might work.
I made my own heatsink out of copper, and had my headers ceramic coated. (on my boosted Maxima) My LC-1 and XD-16 work flawlessly. I can send you a pic if you want.
Awesome. Great to hear. Nice setup too. :top:I did a home made dual heat sink and then cut the crappy terminator plug out and soldered it, now it works perfect, every time.
I now get to compare A/F-R readings between the Innovate and Scanguage-II, they are dead on the same all the time.
Soes this codes work for any vehicle
But the refresh rate on the Scangauge is slow, and this feature doesn't work on all vehicles. Also, most vehicles run off a narrowband sensors, not wideband, so I don't think the Scanguage will take away any business from wideband arena. :top:Sales on the SC-II will skyrocket since it has more features than a wideband and accurate afr readings. (if it is confirmed accurate)
