Sittin Sic HOW TO...
Discussion in 'XII Performance' started by Shanes56, Feb 17, 2008.
  1. Shanes56
    Shanes56 New Member
    Jul 27, 2007
    3,061
    Due to the amount of discussion that has been going on about the time and people being unsure of weather or not they can do the installation themselves and save the cost of installation by a mechanic so here are the installatiojn direction. I will point out that I do not condone trying to install this kit without professional supervision or help!
    Sittin Sic Coil Installation
    IMPORATANT
    Before attempting to remove and install any automotive coils it is important that you have the proper tools and facilities. Sittin Sic does not take responsibility for any negative effects or injury that may occur while removing or installing or there after ofthe Sittin Sic coil springs.
    Sittin Sic strongly recommends that an ASE certified professional handles all removal and installation of the Sittin Sic coils.
    Removal of stock shock absorber and coils spring assembly
    • Disconnect negative battery terminal
    • take the proper steps necessary to remove front wheel
    • Separate skid control sensor
    • Separate front flexible hose
    • Remove front upper suspension arm
    • Remove front shock absorber and coil spring assembly
      • Unbolt and remove the lower shock absorber nut, bolt and washer
      • On the top of the assembly there are three nuts and washers that surround the front support sub-assembly retainer nut. Do not remove the retainer nut only the three surrounding nuts and washers
      • Remove the assembly
    Disassembly of shock and coil assembly
    Important
    Do not attempt unless you have spring compressor properly mounted onto the spring to avoid damage and injury.
    Note:
    Do not use an impact wrench in any of the following steps
    • Remove the front support from front shock absorber nut
      • Using the proper spring compressor compress the coil
      • While holding the shock absorber rod remove the nut
    • Remove front shock absorber cushion retainer
    • Remove front suspension support sub-assembly
    • Remove front coil spring insulator upper
    • remove front shock absorber cushion retainer
    • remove front coil spring
    Reassembly of shock and coil assembly
    Important
    Note:
    Make sure that the front drivers side coil that is identified by the tag is installed on the drivers side.
    • Install Sittin Sic front coils
      • IF necessary compress the Sittin Sic coils (due to the reduction in height of the coils compression may not be necessary)
      • Install front coil spring onto the shock absorber. Fit the lower end of the front spring into the gap of the lower seat
    • Install shock absorber cushion retainer
    • Install coil spring insulator
    • Install suspension support sub-assembly
      • Be sure that the bolts line up with the upper mount holes
    • Install cushion
    • Install cushion retainer
    • Install support to shock absorber nut
      • Fit and tighten the lock nut (preferably new). Torque to 20ftlbs
      • Release coil spring while checking the position of the suspension support sub-assembly
    Installation
    • Temporarily tighten shock absorber with coil
      • Drivers side
    i. Install onto the body with the lower end of the spring facing the outer side of the truck
      • Passenger side
    i. Install onto the body with the lower end of the spring facing the inner side of the truck
      • Install three nuts and washers onto the upper side of the shock absorber with coil. Torque to 47ftlbs
      • Temporarily tighten the lower shock mount nut, bolt and washer
    i. Temporarily tighten supper suspension arm
    ii. Reinstall flexible hose
    iii. Reinstall skid control sensor wire
    iv. Put the wheel back on
    v. Lower and stabilize the suspension by bouncing the truck up and down several times
    vi. Raise vehicle and remove wheel
    vii. Fully tighten lower shock absorber mount nut, bolt, and washer. Torque to 61ftlbs
    viii. Fully tighten upper suspension arm
    ix. Reconnect negative battery cable
    Align vehicle ASAP to avoid improper tire wear
    #1 Shanes56, Feb 17, 2008
  2. DallasCowboys
    DallasCowboys Banned
    Jul 7, 2007
    1,612
    Wow, Thanks Shane! Now I can save that money. :top:
  3. skilledbum23
    skilledbum23 New Member
    Jul 6, 2007
    2,018
    ahhhh looks like i am going to have fun now, that the wedding is done and over and the family is on there way home
  4. Shanes56
    Shanes56 New Member
    Jul 27, 2007
    3,061
    Make sure to post up pics, and give yourself plenty of time and enough to drink! :top::biggrin:
  5. TitanRattler813
    Feb 28, 2007
    7,656
    33
    I just found out the wonderful news that I can rent a torque wrench from AutoZone :rockon:
    So... anyone have the socket sizes I'm going to need for the front and rear? (so I don't have to go all the way home to check if I have them before stopping to get the spring compressor). Lowes is right across the street from work and I plan to knock this out tonight and get aligned tomorrow :biggrin:
  6. eXuser01
    eXuser01 New Member
    Jan 21, 2008
    2,569
    17mm 19mm open end wrench and socket for both 10mm 12mm 14mm and open end wrench for those also i forget what else i used make sure you torque them really good also buy those tool kits that the bolts can go thur the socket and socket wrench for the 2" lowering blocks bc the ubolts are too long
    [​IMG] they are called gear ratchet
  7. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Thanks, that's just what I needed... I already have the Kobalt socket set, but don't recall all the sizes. Do the U-bolts need trimming at all if I use those? I gotta get some wrenches.
  8. eXuser01
    eXuser01 New Member
    Jan 21, 2008
    2,569
    i didnt trim mine but it was a bitch to put them on i had to make a tool to make it work..if you get that tool kit it will save you a headache and make things a lot faster and you wont need to trim :top:
  9. RJDoute
    RJDoute "My Salami Nipples Ooze Milk"
    Mar 4, 2008
    3,360
    This looks too complicated for me. Shane, wanna install it for me? =P
  10. Vince77
    Vince77 New Member
    Feb 22, 2008
    4,020
    Got the ASE certification, now I just need the kit. :biggrin:
  11. Hi_On_X
    Hi_On_X New Member
    Feb 25, 2007
    5,155
    It's pretty simple, Not hard at all....
  12. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Well... I'm sittin halfway sic right now. I rushed home from work to do as much as I can before the sun disappeared. Only snags I ran into are:
    1. I printed the instructions and for some reason couldn't find them halfway through removing the stock spring assembly, so I didn't use them after that.
    2. One tool I was missing was an adjustable wrench. I had to sprint to autozone and back since my truck was on jackstands. It's only about 5-6 blocks away. Lucky for me I'm a fairly healthy young man, lol. The adjustable wrench was necessary to get the retainer nut off the top of the spring/shock assembly. I sat there for like 20 minutes turning like a jackass expecting the thing to pop off and realized that maybe the boxed end shouldn't be turning along with the nut. So yeah, I'm a retard, but I figured it out. After trying several failed attempts with tools I had around, I just gave up and ran to the store.
    3. Since I didn't have the instructions, I just pretty much took everything else apart and put em back together. I didn't drop the truck, bounce it up and down, do the hokey pokey, turn myself around or any of that stuff. I hope it doesn't matter cuz I don't really wanna do it all over again and I'm getting an alignment first thing in the morning.
    4. Don't be afraid of the spring compressor. I was terrified of that thing and was moving all extra slow on the first spring. There's no need. Just make sure the contour of the compressor follows the contour of the spring and the pins are in there good before you tighten it down.
    5. WEAR MECHANICS GLOVES: I get cut everytime I install something on my truck. This was no exception. I lost some skin trying to break nuts/bolts loose... It happens.
    Conclusion: The install up front is very simple. Two hours is reasonable and it can actually be done faster. Mine came into a little under four including lots of wasted time and a jog to the store and back. I expect the rear should go fairly quickly tomorrow night. That's a pretty straightforward install.
  13. Spyder327
    Spyder327 New Member
    7,098
    Can't wait to see how that thing looks Sean :top:
  14. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Hehe... I had one of those little kid grins when I took the jack and jackstands out. I can't fully appreciate it because my truck is now filthier than I've EVER seen yours. :frown: Looks like it's not getting detailed for our trip on Friday because there's a slim to negative chance I wake up and do it on Friday morning :rolleyez:
  15. XrunnIT
    XrunnIT Active Member
    Jul 29, 2007
    8,044
    Ya the install is pretty straight forward. Can't wait to see pics. :top:
  16. jaxchrisfla
    jaxchrisfla Active Member
    May 29, 2007
    7,560
    I will be doing an install in the next week or so, so i will actually video the install if it will be helpful for peeps. Ill have pics at least for sure.
  17. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Sorry... you're gonna have to wait to see it in person.
    I actually have zero pics b/c I was rushing, lol. I usually at least take a pic of the box/package before I install them... not this time. Oh well, looking forward to that how-to vid. :top:
  18. XrunnIT
    Jul 29, 2007
    8,044
    I've got all the pics for the write up. most of the pics are already online, there are few that i forgot to upload. Probably do that when i get home. :top:
  19. jaxchrisfla
    May 29, 2007
    7,560
    where the pics? im doing the front tomorrow, i already did the rear. still debating on the actual video footage as well. we will have two people there, and at least one of us will have a camera in hand at all times
  20. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    I received my front coils yesterday. I did not realize they were progressively wound (which is good). I assume the small end goes up?
