Now it makes sense!
Like I said, this VVTi/VSS relationship is something I do not understand, but I know it to be true. Early on in the X-1 development I had a problem with getting a clean speed sensor signal getting through the X-1 and my VVTi system was constantly flopping back and forth causing a very bad power surge in cruise. This was from the VVTi system constantly hunting. The result was very significant even at part throttle. My findings and what I discovered would fix it led to a physical modification to the X-1 main board.
I have seen the damaged cam with the burned up thrust bearing and I know that to be true.
Like I said I was asked to pass this info along. The source is very credible.
See, i would a thought that it would just stay in like a "fail safe mode", like an off position. I wouldn't have guessed it would go "hunting" for the signal... learn something new every day!
Like said, i don't know much when it come to newer engines. :dontknow:
I also didn't know you played a part in development of the X-1!!! I definitely believed you before, but like i said, i was just wondering!!! :top:
Ill keep my speed switch off, cause i definitely can't afford a engine rebuild....:frown:
BTW the check engine light went off after 3 engine start/stop runs. i thank you for your knowledge, BTW.:adore:
BUUUT....
Would there be any way to "kill" the governer, but not interrupt the VSS signal? Other than a X-1, of course. What about for the speedometer? Mine is already way off cause of the 4.10 gears. What if i wired in a switch for it? Would that kill the governor, or is that all based off of the VSS? The VVT-i doesn't use the speedo at all right? :hmmmm2:
