SignUp Now!sweet build!
Are your tires cold when this happens? You do live in Canadia.
you should try my X out with URD's traction bar wilson
it's a world of difference and IMHO #2 mod after SS
Does it actually help with handling? I was always under the impression that it was for reducing wheel hop under hard accelerations.
And on another note, you know I can't drive your X…. or else I would have to buy a BBK haha. :argh:
I think the truck is acting up again. I believe it is the intercooler pump again. On a cold start it makes an electrical whine noise. It just started doing this around a week ago. After 5 minutes of idling it will go away. It was presenting the symptoms very similar to last time my inter cooler pump went. Would you guys agree that it sounds like something else? I checked all my fluids and it isn't the power steering fluid low or anything like that. Also what is the upgrade instead of the OEM bosche pump?
Did a little of searching once I realized that I spelled Bosch wrong. Gadget said to look into the Johnson M-30 or C-30. The only Johnson one that looks like the OEM one is the CM-30. It looks correct though. Can anyone help me out confirming that it is equivalent? I don't really want to blow 175$ on one that doesn't fit.
Thanks
in the same boat - dont think bearings, think it's my intercooler pump too
lemme know what yo find - it is here somewhere...
Yeah that's the one... It's quiet n fast... Look on ebay.
The Johnson one.
Thanks for the clarification on which pump. I'm definitely looking to upgrading to the Johnson. I was reading in the 55 AMG forums about upgrading the pump. Apparently some of the cars have the same Bosch pump as we do.
Yeah wen mine went out Bulldogger and G told me about it and to get it no B.S.
