SignUp Now!Thanks. I see why it is so cheap. Likely a journal bearing turbo. All silicone coupling intake and charge "pipes". No intercooler, no injectors, no tuning.
Simple recirculation valve, and internally wastegated.
Simple kit, and great to build upon if you want to add in an intercooler and other components.
The most important part of that kit is the header. Which they have hidden.
iniazy, how much is that alpine supercharger?
Torspd, Now that I have my wheels, will get suspension and big brake kit soon...I just need a little bit more power. If I get the oz boost turbo kit... would it be easy for you or someone local in SoCal to me like MadTaco461 over at TW forum to install? I just want an experienced person /shop to install and do the job right the first time.
Just trying to find my options of small boost... last resort is no boost and just regear to 3.73" and headers from LCE.
On the Prado, is the radiator also used for transmission cooling similarly as the 1GR?
With the added power have you noticed large increases in transmission fluid temps, or is it also a combination of the tire size, heat and power?
I truly dislike the throttle lag from these ecu controlled TB's. For that reason specifically, I purchased the ProEFI Pro128, as it can fully be programmed to control the throttle body. It is much more linear when the ProEFI controls it versus OEM. That also affords me the ability to remove the speed limiter while controlling the throttle body.
You could say that I took the expensive route.
