T56 Write UP
Discussion in 'F/I Mods & Tuning' started by revobreaker, May 24, 2013.
  1. Gadget
    10,903
    152
    Did a few short drives over the weekend. Looks like this new combo is working very nicely.
    Had a T56 Magnum built with these ratios:
    2.97 2.07 1.43 1.00 .74 .63 and running with my 4.10 diff ratio
    The outer casing is just like the Camero version I had. Rear mount, shifter and so on all the same. Even got the same input and output splines so everything bolted right up.
    Now I have an extra T56 transmission freshly rebuilt with about 1000 miles on it. Wonder what I will do with that???
  2. revobreaker
    revobreaker Moderator
    Nov 8, 2007
    3,149
    10
    Trade with me for mine that has unknown mileage and unknown parts!
  3. Torspd
    51
    That is great to hear Gadget. And now that you have that nice 4.10 rear gear, you will be able to make it to The Texas Mile. :D. Or something more local to yourself. :)
  4. widdoz runner
    widdoz runner New Member
    Mar 29, 2011
    421
    Whos doing the t56 sales is it still apr?
  5. revobreaker
    Nov 8, 2007
    3,149
    10
    Maybe, call them and ask.
    This thread is to discuss the technical aspect of the swap only
  6. revobreaker
    Nov 8, 2007
    3,149
    10
    My TOB started squealing at XFE, it does it especially when its cold and I have to slip it on a hill.
    I know I will have to address it sooner or later so I have a question:
    How much variation in the measurements could I have? Rather then dropping the trans and measuring, then putting it back together, then getting spacers, going through it all again.....
    Anyway, could I order the .75 spacer and then a few shims to have on hand and do it all at once?
  7. Gadget
    10,903
    152
    Yep, you could do it all at once.
    I have an extra thin shim if you need it. No idea what I got two of them.
    Just from the feel of it, the GM unit that Coupe suggested feels like a much higher quality unit.
  8. revobreaker
    Nov 8, 2007
    3,149
    10
    what shims should I have on hand "just in case"
    What clutch options to you have right now G?
  9. Gadget
    10,903
    152
    My guess and guess only will be get the same thing that Coupe and I are using.
    We both came up with the same measurement and spacer thicknesses. He has an OEM type clutch and I have the URD TwinDisc so I am sure you will be right in there as well.
    Like I said, I have an extra thin one if you need it.
  10. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    15
  11. revobreaker
    Nov 8, 2007
    3,149
    10
    Gadget, did you buy the spacer from ram clutches or did you have one machined?
    Ill probably save the clutch upgrade actually, dropping the trans is a yearly event at this point so I want to make sure I have something to do to it next year lol
  12. Gadget
    10,903
    152
    The thin spacer I have is a pretty red and I got it from AMS.
  13. revobreaker
    Nov 8, 2007
    3,149
    10
    no no, the .75 spacer
    I will want to snag that thin one tho...
  14. Torspd
    51
    From solid to sprung.
  15. Tokuzo
    Tokuzo New Member
    Oct 2, 2013
    22
    great write up. thanks.
  16. Bang Bang
    Bang Bang New Member
    Sep 10, 2009
    310
    So you kept your factory rearend housing and just changed out the third member?
  17. revobreaker
    Nov 8, 2007
    3,149
    10
    That's what i did. You could keep the same diff and just change the ring and pinion to suit your needs
  18. Doublld
    Doublld Active Member
    Jun 12, 2013
    1,089
    20
    Tor is that rst or rxt?
  19. Torspd
    51
    Sprung hub RXT with the McLeod adjustable TOB.
  20. Doublld
    Jun 12, 2013
    1,089
    20
    1000+ hp capable
