tail light removal tips?
blackXtacy
K, I searched, it is probably easy, but I always like to get tips before I try to remove a body part. Is there a write up on this?
T0LLPHR33
"Catwoman"
its only 2 10 or 12 mm bolts that you use a ratchet to remove...put one hand at the top of the tail light and the other at the bottom and pull straight back...:top: whala they are removed...
2006nightrider
x2...^^^ Two 10mm bolts on each light.
BTW - You'll see 3 bolts going down the side of each light housing, but don't worry about the middle bolt, you don't need to remove it; just the top and bottom bolts:top:.
Generation-X
Hmmm strange mine only has two small 8mm bolts in the back side and none of the side.......lol
T0LLPHR33
"Catwoman"
you sure cause they are 10mm...3 of them to be exact top and bottom are the only one's you need to remove...
are you sure your looking in the right place? either way can you post a picture for us and we'll let you know if that's the correct 1's or not...
2006nightrider
He's being a sarcastic smartass Jay:laugh:...remember he has custom lights and roll pan:top:
