SignUp Now!This entire thread is BS.
zip ties and duck tape?
It would have been awesome made out of old pop-tart boxes
Wasn't going to say anything...driver mod. He needed to lower his tire pressure....running the exact same suspension, same tires (mine are 20mm wider, on 50mm wider rims.) Rocking a SLIGHT, stretch/square, setup. I lowered my tires down to 20psi...second run of the night, layed down the time in my sig, same Night as butters at texfest. Told him to lower his tire pressure down to something under 20psi, and do a second gear burnout to warm em up. OEM tires size is slighlty bulged on a 8" rim, so if you get the tire pressure down low enough, You can take advantage of that sidewall flex.:top:
Lowering your tire pressure with our tires doesn't help your case very much... Our sidewall doesn't have very much give and can run the tire if that sidewall does give out. :top:
Uh huh. Next your going to tell me, nitrous isn't flammable....riggggggghhhhhhhttttttt....
Nitrous Oxide is an oxidizer, it help flammable materials burn but does not burn by itself. Also, doing burnouts on street tires to warm them up and stick better to the pavement will not work. That works only for pure race type tires.
^^ This guy knows. :top:
Excellent response sir! Please don't take the following in a negative light as I only mean to compliment....
Many adults could not have written such well thought out paragraphs, I have never met a teenager who could write as well.
30 years ago I used to drag race a beater Camaro. A few racing buddies and I would go to the track with and most of us didn't have the cash for real drag tires. All of us learned quickly that all season tires were not the best for traction. I did at one time get a chance to use a set of M&H drag slicks. Definitely noticed a big improvement in traction after a burnout with those. I understand that tire technology has vastly improved over 30 years, but I still stand by my statement of not doing burnouts on street tires. I recommend that you, or anyone do a google search for "burnout on street tires." Some people say that it improves their et. Most do not.
My main point in posting the above was to point out that N2O is an oxidizer. Since you sarcastically write about the burning ability of "Nitrous" I found you to be an "unreliable narrator" I mean to say that you were incorrect on your chemistry facts, (which you did not address in your recent answer). So why should any take your word on the burnout issue?
I am aware of this, it was a stab at X-troller's fail when he got into it with DS about NAWZ...
and in terms of street tires not getting sticky...depends on the surface. On the street (asphalt), doesn't make a shit of difference. On the track, sir, i kindly beg to differ. I have been down the 1/8th mile in my truck, at least 3 dozen times, with 3 different tire sizes and compounds/brands. Yokohoma s-drives, for instance, they fared much better if i drove around the burn out box and did a quick little burnout to clean them off. Doing a burnout in the box didn't do shit, regardless of gear, time in box or psi. :smile:
With my Hancook's Ventus V12's, ill tell you right now, second gear burn out DOES get them hot, and greatly increases my traction. it greatly varies in terms of tire compound, vehicle, track, hp, etc...there is no way you can say that "all street tires do not get sticky"
Another thing i noticed. while drifting, certian tires fare better then others. When i drifted on my Ventus v12's (255's), they would survive about 30 seconds, then would get insanely sticky. If i kept sliding, they would stay sticky, then, with out warning, twice in a row, they would "d-tread" and fail all together.:ahhhhh:
On all the china brand tires, i have raced and drifted on (nexan, fullrun, achillies), no matter how hot they got, or how many back to back runs i did, they would just get progressively hotter, but not any stickier. +1 to your theory. When i slid in Houston, i got to slide on a set of OEM bridgstones. Those, would get hot, slightly sticky, then taper off a tad and not change at all. Very strange breakaway, and heat cycle IMHO. I did, oh, i'd say four hot laps on one set of the the BS, and they still maintained that same behavior. I kinda liked them, actually. Extremely predictable, and surprisingly good tread life. To bad they cost as much as like 4 china tires, for just 2 BS. :rolleyez:
There are far to many brands of tires, tracks, weather conditions, for you to safely say that ALL street tries don't get sticky when doing a burnout. I have found only one, brand, where doing a burn out actually helps. My Toyo Proxies and S-drives, along with the china tires, did not find the burnout very helpful. while, the V12's made a very dramatic difference. I have this sinking feeling, that you have NOT tested every single brand and width of tire out there. So Elvis, why don't you kindly STFU, sit back, and enjoy a peanut butter and banana sammich.
and maybe a pop-tart or two. :top:
:rolleyez: Sir, kindly see above.^
oh and, regarding your mod list. You could be amazed at what a few pop-tarts, will power and kind hearted souls can do. :crinklehair:
