The official exhaust thread
Discussion in 'N/A Mods & Tuning' started by 07XR808, Feb 27, 2008.
  1. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    My local Lordco has the magnaflow cat back(17115) cheap ! I will hopefully be getting a afe intake as well...will this cat back and intake yield power gain at all to my bone stock 06? Will it be too loud? Opinions anyone?
  2. hrspwr236
    hrspwr236 Active Member
    Jul 2, 2007
    8,886
    You will see some small gains in power, and if will not be that loud, when you start removing cats is when it gets loud.
  3. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    Ok! Thank you! I'll go for it then! Am I correct to assume that the part number I gave before hand is the same exhaust others have been talking about?
  4. hrspwr236
    Jul 2, 2007
    8,886
    That is the one for offraod and the tail pipe ends before the axle and will not go to the Xrunner opening in the body kit but it's uses the muffler that most owners use to cut the factory muffler out and weld in. It will sound great but just know what your getting.
    http://www.magnaflow.com/02product/displayapplications.asp?partnumber=17115
    This is the Xrunner specific magnaflow Catback
    http://shop.advanceautoparts.com/p/...a=pla&ci_kw=&gclid=CJnzmNPOsb8CFUdcfgod9FYALg
    It's cheaper to buy the URD which is the same thing
    http://urdusa.com/Exhaust-&-Headers-Exhaust/c93_95/p1260518482/URD-Stainless-3%22-Mark3-Exhaust-2005-2012-Tacoma-V6/product_info.html
  5. shane881510
    shane881510 Active Member
    Feb 14, 2010
    875
    32
    Y pipe sexiness. With just the y pipe and no muffler this thing sounds like a beast.
  6. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    WoW.....I'm Glad I checked! Yeah Lorco guy screwed up! The correct one is much more! The Urd s.s. cat back. is a bit cheaper than the correct one, once it's shipped here to Victoria Canada.
    So I've ordered it! My 06 is bone stock...Will the 3" be to big for my truck? Will the power be to peaky and high in the rpms? Shall i Change my order?
    Imput/reassuring my purchase decision would be appreciated!
    thanks,
    Paul
  7. hrspwr236
    Jul 2, 2007
    8,886
    You will not have any issues with the 3" piping, URD did dyno test and it showed no significant loss on the lower rpms and and overall increase through the whole rpm band. I am straight piped from the factory headers back and have no loss on the low end power that I can feel through the seat of my pants.
  8. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    So I've ordered the urd cat back! I've got a bit more $ to throw at my truck. Should I go for the y pipe?
    Will it give me a check engine light?
    Is it worth it?
  9. hrspwr236
    Jul 2, 2007
    8,886
    Loud is merely opinion but the sound level will definitely increase due to removing the cats. You will not have a CEL as the rear cats are not monitored. I say it's worth for increase power and sound. Of course I like it loud, I have y-pipe and no muffler and I can say that setup is a little loud and not for freeway driving but i think you will be just fine with the URD catback, it's a larger muffler. Just the catback alone is slight louder than stock.
  10. kcidmil
    kcidmil Member
    Jan 11, 2009
    462
    Loud... not really. I have a Aero 3030xl with 3" from the Y back. I was louder than the full Shorty headers, URD Y and URD Cat back.
  11. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    I just installed the equal length headers and the urd cat back(and intake) Sounds great! Yeeehaww ! Sounds so good that I can't stop hitting the rev limiter!!! Defiantly makes the truck a bit peppier! I recommend this combo for anyone.
    Will my stock cat back fit my buddies 4x4?
  12. The EX
    The EX New Member
    Aug 20, 2014
    39
    What's the best bang for your buck with the headers that are out there?
  13. hrspwr236
    Jul 2, 2007
    8,886
  14. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    is this too close? will it damage my body kit? it's the urd mk3
  15. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    or is this really close to the sway bar? anyone else had this problem? any Ideas to improve on?
  16. Torspd
    51
    Can you not rotate the components?
  17. Gadget
    10,902
    149
    I would move it down just a hair.
    You can stuff a large stick into the tip and push it down a hair.
  18. whippersnapper02
    Nov 16, 2010
    394
    18
    TRD
    http://youtu.be/8HEbIKhO3L8
    I tried to record the exterior sound with a mic attached to the bedside above the exhaust but my wind deflector didn't do so well.
  19. AZ Sun Lover
    AZ Sun Lover Member
    Jan 13, 2013
    271
    20
    Loaded Sound Question
    I just found an used older URD 3" cat back. Looks to have two very small resonators before and after the main Magnaflow 5"x11'x22" muffler.
    Plan was to update the rear hanger to fit the latest model Tacoma 2013 to 2015. Than buy an URD Y-pipe. I have been reading until my eyes can't stay open.
    We just bought a 2015 Double Cab Pre-runner and from what I have read is this cab has more "drone" than the Access Cab on the X-runner.
    My question is has anyone here have / had 1st hand experience with this type of set-up? Yes I went through the videos but the ones I found were deleted.
    If so would like to hear your replies! Also does URD have sales like 10% off or N/C shipping anytime of the year?
    Thanks for your replies,
    Randy
    #259 AZ Sun Lover, Mar 30, 2015
  20. pledcan
    pledcan New Member
    Jun 22, 2014
    37
    I have to push the tip back down every time I drive...the connection at the rear of the muffler, and the tail pipe slips.. What have I done wrong? Maybe I've stretched the band clamp? I can keep forcing the nut, but I don't think that's the issue, as the front clamp holds great. Any ideas? I assume a u clamp sucks?
