Alot of us use the Curt as mentioned due to the X-Brace. A pain to install but it works well. You'll have to get a hitch that will lift the ball a little if you want the trailer to be level, i think mine is a 6" raise. Towing is fine once you get that, never had a problem. Also, the biggest downside is i scrape mine on occasion exiting driveways and such with a drop down when i leave front end first. Or i bump it backing into parking spaces with higher curbs. A long vehicle with a low hitch in the back can be an obstacle sometimes.
