Trailer weight cap w/modded X?
DERRIXRYD
Looking into a trailer to get into the BBQ competition hobby.
How does the stock GVWR compare to a modded XR that can handle the extra weight?
Not asking to double the weight but maybe a bit over.
xrgilly
crank up the qa1s and see lol no idea how it will ride just be carefull with thos composits
blackx-runner
"White Flash"
What kind of weight are you looking at? I would think you'd be fine with your mods. I am sure people have towed trailers with the sittin sic drop, but I can't remember any threads about it, or a person who has done it specifically.
If anything you may need to look into a set of helper air bags if you have an issue with the back end sagging or bottoming out when loaded.
xrgilly
i have pulled a 5foot by 10 foot utility trailer with my nearly 800 lbs atv in it with just the ss blocks and stock shocks it pulled ok no real hashness
Air assist bags will get you back to stock ride height.
DERRIXRYD
blastap
I think you will be ok!!
x20Runner05
^^^^ That should tell you that should be ok. A car trailer is pretty heavy. I wouldnt recommend doing it off the bumper. Id say get a hitch for it.
redarkx
Blastap, that looks backwards for some reason. Lol!
fmap4life
good to see that pic, I may be looking into a drag car soon and need to pull it
Gators Taco
The XR is rated for 3500 lbs. I modified the Air Lift kit (59103) to fit on my X.
DERRIXRYD
Thanks guys....Ryan...somehow I thought of that photo after I posted... :top:
blastap
Def recommend a hitch, plus a hitch keeps that weird crease near the gas cap area from forming.
Its no f350 but it works better than you think,lol
Scarface
This thread is great, here I was afraid to bottom out towing a trailer
TahoesHateMe
How much weight are you talking about? I towed 4 sport bikes in a trailer with 1 in the bed with my 06.
NHXRUNNER
"New Hampster"
Derrick just make sure you dial up the QA-1s to 10-12 so you don't have to worry about the leaves over flexing. I tow a 16' Glastron bowrider on a regular basis with the same suspension setup. I've had no problems what so ever. And supercharged I imagine you could probably pull a little more weight.
10-12, wow, I run them at 4 with or without the trailer!
