P/N: PTR29-35070 - MAIN SUPERCHARGER KIT P/N: PTR29-35072 - TACOMA FIT KIT Item Qty Req’d Description 1 1 Main Supercharger Assembly with Hardware Bag “B” attached to the coolant nipples at the rear of the intercooler lid. 2 1 TRD Air Filter (not illustrated) 3 1 Hardware Bag “C” 4 1 Hardware Bag “D” 5 1 Hardware Bag “E” 6 1 Hardware Bag “F” 7 1 Hardware Bag “G” 8 1 Hardware Bag “H” 9 1 Hardware Bag “I” 10 1 Hardware Bag “J” 11 1 Hardware Bag “K” 12 1 Hardware Bag “L” (White Envelope) 1 1 Heat Exchanger - Low Temperature Radiator (LTR) 2 1 Hood Support Bracket 3 1 Hardware Bag “A” Hardware Bag “A” Contents Item Qty Req’d Description 1 1 Installation Instruction Manual 2 1 Reservoir Bracket 3 2 Rubber Grommet 4 2 M8X20mm Hex Flange Head Bolt 5 1 Spacer, .50” Dia X .75” Long 6 1 M6X50mm Hex Flange Head Bolt 7 1 M6X20mm Dia Washer 8 2 Spacer, .75” Dia X .75” Long 9 2 M8X30mm Hex Flange Head Bolt 10 1 10 Amp Mini Fuse 11 1 Ring Terminal, 12-10 GA 12 12” 5/16” EVAP Hose Hardware Bag “B” Contents Item # Qty Req’d Description 1 6 M8 X 35 mm Reduced Shank Hex Head Bolts Hardware Bag “C” Contents Item # Qty Req’d Description 1 1 Tensioner Bracket Assembly 2 1 5 Rib Belt 3 1 Smooth Idler Pulley 4 1 5 Rib Idler Pulley 5 1 Tensioner Strut Bracket 6 2 M10 Double Ended Stud 7 2 M10 Hex Flange Nut 8 1 M8X16mm Hex Flange Head Bolt 9 2 Short Spacers 10 1 Idler Spacer with Groove 11 1 Idler Spacer without Groove Hardware Bag “D” Contents Item Qty Req’d Description 1 1 Upper Idler Bracket Assembly 2 3 M8X20mm Hex Flange Head Bolt Hardware Bag “E” Contents Item Qty Req’d Description 1 1 Crank Pulley 2 1 M16X70mm Hex Head bolt 3 1 M16X48mm Dia Washer Hardware Bag “F” Contents Item Qty Req’d Description 1 1 Supercharger Support Bracket 2 1 Air Box Bracket 3 1 VSV Bracket 4 2 M6 Hex Flange Nut 5 1 M6 Washer 6 1 M6X16mm Hex Flange Head Bolt Hardware Bag “G” Contents Item Qty Req’d Description 1 1 Thermostat Spacer 2 1 Water Pipe Spacer 3 1 O-ring – Large 4 1 O-Ring Small 5 2 Spacer 6 5 M6X55mm Hex Flange Head Bolt Hardware Bag “H” Contents Item Qty Req’d Description 1 1 Wire/Conn Assembly 2 2 Adel Clamp, #36 3 8 Wide Band Spring Clamp 4 10 Tie Wrap, 7.5” 5 1 Hose Mender Fitting, ¾” 6 2 Hose Clamp, #10 7 1 Adel Clamp, #16-2 8 1 M6X20mm Hex Flange Head Bolt 9 1 M6 Hex Flange Nut 10 2 M6X16mm Hex Flange Head Bolt 11 1 15 Amp Fuse 12 1 Fuse Tap-In 13 1 Female Terminal, 16-14 Ga 14 4 M6X12 Hex Flange Head Bolt Hardware Bag “I” Contents Item Qty Req’d Description 1 1 Intercooler Pump 2 1 Coolant Reservoir with Cap Hardware Bag “J” Contents Item Qty Req’d Description 1 96” 1” Wire Loom 2 1 ¾” x 4” x 36” Coolant Hose 3 1 ¾” x 4” x 60” Coolant Hose 4 96” ¾” Coolant Hose 5 1 ¾” Formed Coolant Hose, LTR to Pump Outlet Hardware Bag “K” Contents Item Qty Req’d Description 1 1 Lower Radiator Coolant Hose (loose in main box) 2 6 Spark Plugs 3 6 Fuel Injectors Hardware Bag “L” Contents Item Qty Req’d Description 1 2 Sticker, TRD Supercharged 2 2 Sticker, TRD Development 3 2 Sticker, Premium Fuel Warning 4 2 Sticker, TRD Red TRD Logo 5 1 Warranty certificate, TRD 6 1 Warranty Registration Card 7 1 Mirror Hanger, S/C Noise 8 1 Label, Vacuum and Belt Routing 9 1 Label, CARB D-425-20
Thanks to TAPP here is the info for everyone TRD Spark Plug PTR24-35070 TRD High Flow Injectors PTR24-35071 TRD Lower Engine Radiator Hose PTR29-35061 TRD Intercooler Pump PTR29-35062 TRD Intercooler Pump Relay Kit PTR29-35063 TRD Intercooler Hose Kit PTR29-35064 TRD Oil Service Kit, Front Nose Assembly PTR29-35073 TRD Drive Belt Tensioner Assembly PTR29-35074 TRD Idler Pulley w/Bearing, 2.15", Steel PTR29-35075 TRD Idler Pulley w/Bearing, 2.30" Ribbed, Steel PTR29-35076 TRD Idler Pulley w/Bearing, 3.0" Ribbed, Aluminum PTR29-35077 TRD Idler Pulley w/Bearing, 3.0" Flat Steel PTR29-35078 TRD Front Nose Cover Replacement Assembly PTR29-35079 TRD Low Temp Radiator (Tacoma) PTR29-35080 TRD Hood Support Bracket (Tacoma) PTR29-35081 TRD Low Temp Radiator (FJ Cruiser) PTR29-35082 TRD Hood Support Bracket (FJ Cruiser) PTR29-35083 TRD Supercharger Main Assembly PTR29-35084 TRD Crankshaft Drive Pulley PTR29-35085 TRD Intercooler Assembly & Lid PTR29-35086 TRD Thermostat Housing Spacer & O-Rings PTR29-35087 TRD Supercharger Drive Belt PTR30-35070
From where i can get these parts through online with out the MAIN unit (Main Supercharger Assembly)? i want all the hardware bags from "B" to "L" only..i already have the LTR with hardware bag A
Not sure that you can get them online without buying the entire fit kit. You should however be able to get any part you want from the dealer. Maybe others will be able to give you a hand with an online source. Good luck and congrats on the future boost.
Gotta love this thread! The body shop that did my work said they couldn't find the correct hood latch/I/C pump bracket but now I can call the stealership and check on price and availability. Edit: just called a local dealer and the hood support bracket part# PTR29-35081 can be ordered separate and is $144 and change
I know your not footing the bill but why not get them to order a new fit kit for $300 and keep the spare parts.... Always nice to have extras...
Not sure why they didnt order a new fit kit since the heat exchanger, I/C pump,Hoses and hood/pump bracket was all trashed. Oh ya cause they're RETARDED like any other shop:top: Hows this one though, when I picked it up from the body shop I also noticed a pulley/belt noise and tonight while driving I noticed I wasnt making any boost. Opened the hood to find no more noise and no more Blower belt! belt was gone! So now I gotta see if an idler pulley is ceased up because the blower pulley turns as it should. Why me?
Think if I order the 1gr supercharger tensioner assy, part #PTR29-35074, that it will come with the parts included in the C bag. Im trying to piece some of this stuff togeather for a used TRD charger I picked up on ebay. I ordered the trd crank pulley and it came with the bolt and washer much to my suprise. TRD support is just some rep bound to a desk and phone. They know nothing of what is included in the parts ordered or i just havent talked to the right one.
Do you have the Install instructions? I have it in Pdf format if you want i can send it to you. pm me your email.
Would anyone know or maybe be willing to find out what tread size and how long the 2 double ended studs are that are used for the idler pulleys on the TRD supercharger assembly? I think I can possibly find a replacement from FASTENAL but I currently dont have anything to compare it to. Also how long the spacers are as-well. These small parts are not included in the tensioner assembly when ordering from Toyota much to my dismay. Any help or input would be much appreciated. They are included in the C bag.
Anyone have any info, or ideas on how to obtain the rubber grommet for the LTR. I bought my S/C kit used, with the parts "supposedly" all there. The boxes looked full and looked like everything was there. Upon further inspection, the LTR is missing one of the rubber grommets.
