TRD Supercharger Maintenance??
Discussion in 'F/I Mods & Tuning' started by jmoore120, Jun 11, 2009.
  1. jmoore120
    jmoore120 Active Member
    Dec 13, 2007
    1,457
    So a guy a work was asking me how to change the oil in my TRD Supercharger. I told him that as far as I know, our superchargers are self contained. Anyone have any info on this? Perhaps Gadget will chime in on this one.
  2. Gadget
    10,900
    149
    http://www.gadgetonline.com/SuperNose.htm
    You can change the oil in the nose drive. You have to remove the plug and use a suction device to remove all the oil in the nose drive. Then refill it with a pre-mesured amount of supercharger oil. You will have to call and ask TRD or Magnuson how much oil this nose drive takes.
    You can get the oil from your local GM dealer. It comes in 4 oz tubes.
  3. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    Crack her open and drain it...
    Or... Try to suck it all out and pump/fill new oil in.
    The oil is good for a while... and either way will work just fine.
    #3 5H4D0WD347H, Jun 11, 2009
  4. bada$$03taco
    bada$$03taco Member
    Sep 1, 2008
    333
    it would also be wise at around 30k miles to take your belt off the snout pulley and see if you have any slack in the pulley/bearings. at about 32k miles i had my S/C taken off and it had a good bit of play in the front nose drive, and i'm assuming that meant the bearings had slack in them. i'm sure the bearings need to be replaced at 30K miles in order to keep the bearings from going out on you and causing the rotors to hit one another.
  5. 5H4D0WD347H
    Apr 24, 2007
    10,450
    Thats most likely the plastic coupler...
  6. DrEaM MaKeR
    DrEaM MaKeR New Member
    895
    TRD does offer a nose oil kit
  7. jmoore120
    Dec 13, 2007
    1,457
    Would the dealership do this service or would I have to do it myself? If I did this or had someone else do this, how would it affect the warranty of the unit?
  8. braves011
    braves011 "Crouching Tiger"
    Mar 25, 2008
    4,973
    Omar would know this:laugh:
  9. rich017
    rich017 Active Member
    Aug 23, 2007
    6,328
    I think that someone was told by the dealer than it is a non-serviceable unit. So just do it yourself because it would be a lot cheaper anyways.
  10. Gutz
    Gutz New Member
    Jan 8, 2009
    809
    Would this be for the X's TRD SC only? or would it apply to all TRD SC's?
  11. trd_sport
    trd_sport Active Member
    Feb 18, 2007
    6,563
    all of them...the only thing different between the models is the fit kit.
  12. DrEaM MaKeR
    895
    Matt i think he is asking about the tundra
    But yes they do offer and oil service kit for all
  13. trd_sport
    Feb 18, 2007
    6,563
    :adore::adore::adore::adore::adore::adore::laugh:
  14. Gadget
    10,900
    149
    The dealer is not likely going to touch it as TRD's position is that it has a maintenance free service life of 100,000 miles.
  15. jmoore120
    Dec 13, 2007
    1,457
    Thanks G. Was just wandering because I didn't find any information in the forums regarding this.
  16. blastap
    blastap New Member
    May 20, 2007
    4,247
    100k is a long time on gear oil.
  17. JeffSnAusTX
    JeffSnAusTX Member
    Apr 3, 2008
    198
  18. Aspen_S/C
    Aspen_S/C Member
    Feb 28, 2008
    251
    This thread is being revived:
    So my TRD blower has about 75,000 miles on it and the spark plugs, 65,000 on the snout oil, 40,000 on the belt. It is doing well, 6 pounds of boost at 8,000 and above, up to a whopping 9 PSI on the East coast one day at sea level last year, but I am rarely there, usually above 6,000 feet and often above 12,000. The sound has not changed, the belt looks good all around. I am running the URD red 2.825 pulley, 1st gen. TRD CAI.
    I was going to do work on it next year when I am hoping to put a good bit of money into, headers, bigger injectors, Walbro 255, a MapECU3 ( X1 seems extinct ) and have Gadget get it dialed and just put in new plugs for now, but according to this thread and from what I can see my self, it looks best to remove the blower to get to the driver side plugs ( yikes )…..( damn )…..( crap ).
    This vehicle sees duty not unlike that of industrial application vehicle since it is used for commercial purposes full time, so preventative maintenance is a more cost effective option and at this point, I love working on it, everything is out of warranty but paid off:
    http://kodachromeproject.com/blog/
    So what I am planning on doing at the moment is replacing the plugs, pulling and cleaning the intercooler component, installing a catch can, replacing the snout oil and possibly the plastic coupler if I can do it without removing the input shaft and one time install aluminum URD pulley. I am also looking to pull the blower apart to get to the lobes / impellers to clean oil and goo off of those too. So from what I can tell from my install instructions ( Toyota did the install ) to get the blower off, I disconnect all hoses, de-tension the belt, pull the intercooler out, unbolt the blower from the manifold, front idler assembly, bracket, throttle body and pull it out.
    Any insight, experience or tips with this, especially pulling the blower out and getting to the impeller lobes? And what about doing compression tests when you have to take the blower off to get to the driver side bank while it is still warm, that seems like a conflict of operatives?
    Just ordered the Walbro 255 for now, figure it is a safe thing to do, I'll do bigger injectors, MapECU3 / X1 when I do headers and such...
    #18 Aspen_S/C, Sep 25, 2011
  19. outlaw7
    outlaw7 Member
    Apr 18, 2010
    633
    the blower is pretty simple to install/uninstall. all you have to do is disconnect the coolant lines, remove the intercooler, loosen the 6 bolts inside the intake chamber, remove the belt, then the 4 bolts i believe, in the front and 2 along the d/s. pulled mine in about 30 mins, reinstalled in about 25. as far as the internal work should just be removing the nuts on the front snout im guessing. prob easier to change the oil with the blower off also.
  20. Aspen_S/C
    Aspen_S/C Member
    Feb 28, 2008
    251
    For Pete's sake, I have called around, emailed all effing day long and I can't believe I can't get a straight answer out of anyone on the following:
    I lost the paper that PSE superchargers sent along with my nose drive re-build some time ago that had the torque settings of the bolts on the nose drive, the type of sealant used and how much oil to put in ( I think it is 6 OZ. ).
    Anyone know the answer to this? I am scheduled to do this maintenance tomorrow so I can get the truck to my mechanic the next morning to install the new fuel pump so I can get back to using this thing for work.
    This forum seems dead lately, can anyone chime in?
