TRD Supercharger Nose Drive Seal
Discussion in 'F/I Mods & Tuning' started by StreetTaco, Jul 8, 2020.
  1. StreetTaco
    StreetTaco New Member
    Jul 7, 2020
    6
    I have the TRD Supercharger on my '12 and the nose drive seal is leaking. With only 6 oz of fluid I can't say if it is "bad" but it is a a spreading pattern but not dripping yet. Something of a class 1 leak.
    I am trying to get a part number for the nose drive seal. Dealer said all they can do is replace the entire nose @ $2000. Contacted Magnuson and was only told to contact SCOL for a rebuild. Contacted SCOL and they gave part # EAT-101687. I'm concerned that it doesn't list the MP90 as a compatible interchange.
    Can anyone help verify that this part # does interchange or give one that does?
    Thank you in advance.
  2. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,985
    84
    I don't know, but try contacting these guys:
    https://superchargersonline.com/contact/
    Found this parts list on another thread:
    TRD Spark Plug PTR24-35070
    TRD High Flow Injectors PTR24-35071
    TRD Lower Engine Radiator Hose PTR29-35061
    TRD Intercooler Pump PTR29-35062
    TRD Intercooler Pump Relay Kit PTR29-35063
    TRD Intercooler Hose Kit PTR29-35064
    TRD Oil Service Kit, Front Nose Assembly PTR29-35073
    TRD Drive Belt Tensioner Assembly PTR29-35074
    TRD Idler Pulley w/Bearing, 2.15", Steel PTR29-35075
    TRD Idler Pulley w/Bearing, 2.30" Ribbed, Steel PTR29-35076
    TRD Idler Pulley w/Bearing, 3.0" Ribbed, Aluminum PTR29-35077
    TRD Idler Pulley w/Bearing, 3.0" Flat Steel PTR29-35078
    TRD Front Nose Cover Replacement Assembly PTR29-35079
    TRD Low Temp Radiator (Tacoma) PTR29-35080
    TRD Hood Support Bracket (Tacoma) PTR29-35081
    TRD Low Temp Radiator (FJ Cruiser) PTR29-35082
    TRD Hood Support Bracket (FJ Cruiser) PTR29-35083
    TRD Supercharger Main Assembly PTR29-35084
    TRD Crankshaft Drive Pulley PTR29-35085
    TRD Intercooler Assembly & Lid PTR29-35086
    TRD Thermostat Housing Spacer & O-Rings PTR29-35087
    TRD Supercharger Drive Belt PTR30-35070
    http://www.xr-underground.com/threads/trd-s-c-parts-list.33429/
    mejbro likes this.
  3. StreetTaco
    Jul 7, 2020
    6
    For a follow up, I finally got to doing the repair and indeed that was the correct seal/part number. Could only retrieve 2 oz of fluid but only got about 3 oz back in before it was over flowing out of the fill port.
    mejbro likes this.
  4. StreetTaco
    Jul 7, 2020
    6
    It is a month later and I found the new seal is leaking badly. Took it apart and the inner rubber ring has disappeared from the seal. Replaced it with one from ZZPerformance. Fits well, though it is rubber coated instead of exposed metal. Now to wait and see how it fares.
    #4 StreetTaco, Dec 1, 2020
    Edgeman likes this.
