trd supercharger questions
Discussion in 'F/I Mods & Tuning' started by dmbfan73, Mar 12, 2009.
Thread Status:
Not open for further replies.
  1. dmbfan73
    dmbfan73 Active Member
    Sep 23, 2008
    1,156
    so my taxes are soon to arrive and i'm gona hook my x up with the trd s/c. question is i dont know squat about tunning, and very little about performance mods. what would you all suggest i purchase, in order from most to least important to get the most out of the s/c? thanks fella's :rockon:
  2. T0LLPHR33
    T0LLPHR33 "Catwoman"
    Jun 17, 2008
    10,969
    APR X-1...:rockon: enough said...
    URD Smaller Pulley...
  3. Yotaman
    Yotaman "Shortbus"
    Jan 25, 2008
    5,345
    The dealership will falsh ur ECU, which will have a tune for the S/C. :top:
    Then you can spend :
    $600 on a MAPECU2
    or
    $1300 on an X-1
    You don't need either of those, but they make the S/C run better.
    www.urdusa.com
    #3 Yotaman, Mar 12, 2009
  4. Gadget
    10,896
    144
    Yep, the X-1 is the hottest thing going for the 1GR supercharged or not.
    URD has it in stock ready to ship. You can give me a call any time if you have any questions. URD is down in Orange County CA.
  5. dmbfan73
    Sep 23, 2008
    1,156
    run better as in how? like i said i dont know diddly about tunning. if someone can post numbers for me that would be great.
    thanks gadget! i was hoping you would chime in on this one. without asking you to write a novel about the x-1, could you give me the "short n sweet" on the x-1?
    #5 dmbfan73, Mar 12, 2009
  6. Yotaman
    Yotaman "Shortbus"
    Jan 25, 2008
    5,345
    PM Gadget...:top:
    He'll tell you more than you can process. :laugh:
  7. Dekar12
    Dekar12 New Member
    Oct 20, 2008
    411
    Or you could get a new URD S/C... Comes with the x-1 :)
    I just ordered an X-1 from URD last week, but from what Gadget told me, the tune they put on their depends on what mods you have done to the truck and then it basically it self adjusts the afr, etc.
    Further tweaking can be done like rev limits, speedo limit removed, etc. URD worked with APR a lot to make some really solid tunes and if its not quite right Gadget or APR can help you make the adjustments in their software to get it running right.
    The TRD Reflash is a safe/generic tune that is a one size fits all kind of thing. Depending on your mods the ECU may not be able to regulate the afr correctly so you might be running lean/rich at different levels of boost. Gadget has many stories about wonky TRD reflashes and the bugs he has had to try and correct with the apr or map ecu2. Generally speaking the reflash will almost always work perfectly fine with all stock truck as recommended and will usually work fine even with some aftermarket mods. There are exceptions to everything and the reflash is going to be lower power levels then with another tuning method, just because they had to make it so general.
    Gadget would also recommend that if you are going the TRD route, to skip the reflash (cannot go back to a stock ecu flash ever again) and just go with the APR X-1, since it will take over and handle all of the things that the reflash would have done.
  8. Gadget
    10,896
    144
    Just give me a call 877-887-3872 x3 and I can get you up to speed on things much faster than I can type.
  9. XrunnIT
    XrunnIT Active Member
    Jul 29, 2007
    8,044
    These pulls were done on the same dyno (DynoDynamics). Don't compare peak numbers with other dyno's you've seen as all dynos read differently, and can't be accurately compared together.
    Stock - 180.5rwhp/229.9rwtq
    Stock TRD S/C with TRD Flash - 228.8rwhp/279.8rwtq
    TRD S/C, X-1, and bolt-ons - 297rwhp & 320rwtq - 70wrhp/40rwtq gain over stock blower with ECU Flash.
    In short... You have complete control over your tune. You can monitor dam near every sensor in the vehicle. Plus more HP. :biggrin:
    I'm going to put together a "How-To" type walk through for the XTune application.
    Oh.. and you can do this. :biggrin:
    http://www.youtube.com/watch?v=0H-AaAmxBPA
  10. micpun
    micpun New Member
    Apr 16, 2007
    1,315
    makes me wanna get a x-1 so bad.
  11. Wizard
    Wizard Member
    Dec 11, 2008
    323
    6
    That doesn't exactly sound like a fair comparison to me........what about the bolt-ons?? They surely contributed to the additional 70hp gain. What were the bolt-ons?
    I'd like to see:
    Stock dyno (already established)
    Stock TRD S/C with TRD reflash (already established)
    Stock TRD S/C with X-1 tune
    All from the same dyno of course.
    I'm sure the info is out there. Anyone have a dyno/link??
  12. XrunnIT
    Jul 29, 2007
    8,044
    Yes, the bolt ons most definitely had something to do with that 70rwhp gain. The bolt-ons included I/H/E,
    These were done on a DynoJet by ABP on the original X-1 tune (http://www.xr-underground.com/vb3/showthread.php?t=16933)
    TRD S/C, TRD CAI, Muffler, TRD Flash - 294rwhp
    TRD S/C, TRD CAI, Muffler, X-1 - 328rwhp (34rwhp gain)
  13. dmbfan73
    Sep 23, 2008
    1,156
    cool, here's another one for you...should i get the x-1 before i get the trd s/c? and do you know the performance gains?
  14. Wizard
    Wizard Member
    Dec 11, 2008
    323
    6
    Thanks for the info/link. Good stuff. But....I wonder how much of that gain is coming from the cam gears?? I bet at least half of the 34 hp gain is from the gears...
    Anyone install the X-1 w/o the cam gears, tune, then redyno just to see the delta between the TRD reflash and the X-1??? Probably not..
  15. XrunnIT
    Jul 29, 2007
    8,044
    Jaxchrisfla (n/a) was tuned (URD MAF Cal), switched over the X-1 and retuned, and gained like 12rwhp and something around 30lbs of torque.
  16. ntinhri
    ntinhri Active Member
    Feb 1, 2007
    8,104
    i highly suggest going URD s/c! for the money spent you get more gain... if your going TRD blower for warrty. If you start modding your going to void your toyota warrty anyway. SO take it from someone who has one of the most modded out trd xrunner...GO URD. plus x-1 comes with it..
  17. Yotaman
    Yotaman "Shortbus"
    Jan 25, 2008
    5,345
    Listen to this man....:top:
  18. Wizard
    Wizard Member
    Dec 11, 2008
    323
    6
    I should hope so....1.5x to 2x the price of the TRD setup as well.
    Don't forget....for those of us in unfriendly smog states (like CA) the TRD setup makes more sense....hence why I chose the TRD route. If I lived in a different state (like Nevada) I would've gone the URD route. :top:
    Back on topic...
  19. XrunnIT
    Jul 29, 2007
    8,044
    Well... if you want to break it down.
    Here are the facts, based on Gadget's personally built & tuned truck (actual street results have not been seen), and as close to equivalent as we can get.
    Stage I = Supercharger, Intake, Fuel Pump, X-1
    TRD setup equivalent to the the URD Stage I
    TRD S/C - $3500
    TRD CAI - $350
    X-1 - $1300
    Fuel Pump - $170
    TRD Stage I - $5320 - 328rwhp (6psi - ABP) - $16.22/hp
    URD Stage I - $5895 - 337rwhp (7psi) - $17.49/hp
    Stage II = Stage I + Pulley, Headers, Y-Pipe, Exhaust
    Y-Pipe = $469
    CBE = $529
    DTLT = $514
    TRD Pulley = $89
    URD Pulley = $79
    TRD Stage II - $6921 - 351rwhp (9psi @ 6200rpms - Dakota-rt-2a-xr) - $19.72/hp
    URD Stage II - $7486 - 380rwhp (8.5psi) - $19.70/hp
    We will use the APR Stage II kit (2.7" pulley + 7th injector) for the TRD Stage III. We don't have any reported dyno numbers from this kit yet. But based on my truck with a DynoDynamics dyno (that reads low) and 1/4 mile MPH speed, I should be about 340-350rwhp on a dynojet. Lets call it 340rwhp on the stock pulley with the 7th injector. The 2.7" pulley is capable of producing at most 10.9psi of boost (per the engineers at Magnuson, 8.3psi on the stock pulley, 9.75psi on the URD pulley). We'll say 10psi the avg under good conditions. I peak at 6.5psi. So add 3.5psi at 20hp per PSI (again per Magnuson with supporting mods), that's about 70hp gain. That paired with a race tune on race fuel (as the URD Stage III kit was done). Say you only advance 2.5* timing advance at about 4hp per degree, so an extra 10hp. So about 80hp gain (over stock pulley). So we'll call it 420whp (actual results will vary!)
    Stage III = Stage II + Pulley, Race Tune, Grill for URD (as stated on URD's site)
    APR 2.7" Pulley = $389
    APR 7th Injector - $620
    URD Pulley = $79
    Grill - $140
    TRD Stage III ~ $7930 ~ 420rwhp (10psi) - $18.88/hp**
    URD Stage III - $7705 - 422rwhp (8.5psi) - $18.26/hp
    *note prices do not include shipping
    **Prices/Numbers are only estimates!!
    #19 XrunnIT, Mar 17, 2009
  20. ntinhri
    Feb 1, 2007
    8,104
    FYI TRD in the current setup is not carb. smog cert. def not if you do a intake..
Thread Status:
