- Jul 30, 2007
- 8,001
- 305
So they know the truck will need a new ECU?No i never said anything to reverse the reflash. I am selling the truck to the dealer with the reflash installed just no s/c
SignUp Now!So they know the truck will need a new ECU?No i never said anything to reverse the reflash. I am selling the truck to the dealer with the reflash installed just no s/c
Only if the dealership knows the truck needs an ECU.Cool. Sounds like you have a plan. I was just making sure you had all your bases covered.
OV Tuning can nowadays.You can’t “unflash” it.
I understand that. It sounds like the dealer/techs will just replace the ECU. It'll either come out of the trade-in price or the resale markup. That's not the buyer of the supercharger's problem to figure out.Only if the dealership knows the truck needs an ECU.
I may be wrong, but cant you guys just trade ECU's, so OP would have an original one and you'd get the reflashed one?
I'd be all over this if I didn't just blow all my life savings on a new home.
I wanna say you are right. Swapping ecus will work as long as its that same 2WD 6speed manual trans. Trd superchargers can be put back to stock setup if you have a stock ecu from another xrunner that you can swap
VIN is not mandatory to change. Paper clip is enough to learn the key for it.This is partially accurate. It can't be done in the driveway. There is information like the VIN and the key that needs to be programmed through Techstream.
Correct, there will be a CEL.VIN is not mandatory to change. Paper clip is enough to learn the key for it.
P0630? Yes, if a new ECU, but not if the changed ECU is used.Correct, there will be a CEL.
how much are you asking for this kit??I have a 2012. This kit will be complete with all required parts?
Not to mention the question mark...Might want to read the first post
I was asking if the kit would be complete with all required partsI don't follow....maybe it's too early for me
